Old 01-21-2006, 11:00 PM   #1
65 overlander's Avatar
Images: 22
Proper gauge of wire?
The 2 way Black and White wire that, goes from Trailer Umbilical to rear of trailer to Batts. The black insulation is brittle and a new splice wont work, being that the brittleness goes back to far. I replaced the tongue umbilical, Breaker, and common sense says ,Fix all! Any info would be great! Thankyou in advance! Jeff
65 overlander is offline   Reply With Quote
Old 01-21-2006, 11:13 PM   #2
Jim Jarzabek's Avatar
1950 25' Cruiser
Lebanon , Ohio
Images: 16
Wire size
Use #10 gauge stranded copper THHN or THW or THWN you can find at Home Depot or Lowes......
Run new wiring all the way back.... don't splice
If you run the wiring under the belly pan and exposed, go to an r.v. supply house for special two conductor jacketed cable...
Good luck!
Jim Jarzabek is offline   Reply With Quote
Old 01-22-2006, 06:42 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
jeff
since it is your charge line you may want to keep your voltage drop ro a minumum.
this chart may help in your choice of wire.
http://www.poweriseverything.com/imp...20Drop%20Chart
john
you call them ferrets, i call them weasels.
Old 01-22-2006, 06:50 AM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Thanks John, I'm in the middle of rewiring the 18-footer (Boris) and needed a chart like this. LP
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-22-2006, 06:57 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
lee
if you read carefully on that chart you can use 5% voltage drop for lighting.
it will save you a couple of bucks on wire.
john
Old 01-22-2006, 07:04 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
duh
on edit, just use the 2% table, the other one is for 120 volt.
john
Old 01-22-2006, 07:06 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you're really really good at it, and real lucky, you CAN tie the new wire to the old, and pull it through without taking anything else apart.
Old 01-22-2006, 07:36 AM   #8
1967 22' Safari
1960 Caravel
Images: 8
duh
john[/quote]
Thanks, I knew what you getting at. lol
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-22-2006, 10:20 PM   #9
Images: 22
Thank you!
I was thinking of using a wire mesh gripper, to hold the new cable and use the old as a guide. But are there any cable clamps holding the cable from moving around, if so , I dont want to take on removing the belly, but I also understand that running it on the outside would look sloppy! Thank you again for the quick responses. Jeff
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 12:24 PM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
