Old 07-29-2010, 01:40 PM   #1
1994 34' Limited
Chatham , Ontario
Propane use with Generator
I have a built in Onan 2500 Propane generator. I must now use a sleep apnea machine and am going camping where there is no electricity. I have 2 30lb tanks and am wondering if anyone could tell me how much propane per hour I might use?
Ins. Man is offline   Reply With Quote
Old 08-08-2010, 08:17 PM   #2
1981 31' Excella II
Longview , Texas
Images: 14
I too have a CPAP machine and was considering installing a Onan in our 31' Excella II. I'm interested in the propane usage rate as well but equally interested in how you like the Onan? Is it quiet enough for you? Did you install it yourself or did your AS come with already installed?
boo_n_sue is offline   Reply With Quote
Old 08-08-2010, 08:26 PM   #3
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
A 12v operable CPAP machine only draws between 2.5 and 4.5 amp-hours. If you sleep for 8 hours, that's 40-72 Amp hours. A pair of AGM batteries can handle this and be charged in the morning.
That's what I would do, because DC is more efficient, without conversion efficiency losses from AC to DC.
TX-16
Dave Park is offline   Reply With Quote
Old 08-08-2010, 08:33 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Most cg require generators to be shut down before 11pm, so to give you the most leeway in where you can camp, batteries are your best option.
Old 08-08-2010, 08:44 PM   #5
Central , Mississippi
Funny, I just had this conversation with my Dad today...his general rule for a slightly larger ONAN was 1lb per hour...it was usually less but not by much. Even at 1/2 of that you are still talkin 'bout a bunch of propane.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 08-08-2010, 08:56 PM   #6
1981 31' Excella II
Longview , Texas
Images: 14
I may not be reading it correctly but I put a Kill A Watt meter on my AC cord for my Respironics REMStar Pro with CFlex and it read .2 to .4 amps when running without the heater and .6 to .75 amps running with the heater/humidifier.
It doesn't have a DC plug so I'll test it running on an inverter off the battery and post those numbers tomorrow.
Old 08-08-2010, 09:32 PM   #7
1964 26' Overlander
Bentonville , Arkansas
2.5 to 4.5 amps on 12 volts correlates .2 to .4 on 120 volts.
Ginder75 is offline   Reply With Quote
My propane Yamaha Generator from US Carburetion TitusLivy Generators & Solar Power 87 12-26-2011 11:01 AM
Generator Propane Consumption? jking Classic Motorhomes 2 06-30-2010 07:00 AM
Generator vs Propane LittleA Generators & Solar Power 5 05-12-2009 03:11 PM
Propane generator hmurfee Member Introductions 0 06-26-2007 12:35 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 05:03 PM
