Old 04-30-2007, 04:50 PM   #1
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Propane Gas Alarm/Detector Wiring
Seems the propane gas detector in our 2007 Bambi wasn't wired right. No voltage at the propane detector.
Any ideas on where to find the wiring diagram for this? The wiring is a bit on the messy side behind the heater area. What would be my best option to correct the detector?
Not too interested in taking our new Bambi into the local dealer... I would like to be able to camp in it this summer not have it sit for weeks to be fixed.
Tnx!
campadk is offline   Reply With Quote
Old 04-30-2007, 06:37 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings Dave-
You will find the wiring diagram in your manual. The detector should have a straight line to your battery. It is supposed to be set up so that there will always be power to the unit even when all else is down. Should be easy to trace but the first place I would look is to make sure the wires are connected properly to the detector itself. Keep us posted!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 04-30-2007, 06:40 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Hi Dave,
Have you checked the manufacturer's web site? Who's is it? The big 3 in LP detection are Atwood Mobile Products, CCI controls, and Safe-T-Alert.
Also, see if they put the owner's manual in your cute little brief case. If not and you can't find anything on line, let me know and I'll try to dig up some phone numbers for you.
Old 04-30-2007, 06:46 PM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
The propane detector is an "always on" safety device. If the wiring is a "mess", there is likely a "live" 12 volt source in the wires. Use a volt-meter and find the source, and re-attach the wires from the leak detector. Black lead wires are usually the 12 volt (+) and white lead wires are usually the (-) ground.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-02-2007, 06:16 PM   #5
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Solved the problem. Wasn't the wiring, it was a blown fuse! Didn't realize that the propane detector line has a fuse. It's located below the dinette seat beside the fresh water tank. Dealer says that he has seen a few units with blown fuses. Its a 1A fuse.
Replaced it, and were back in business!
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Poor cooling on AC, good on gas Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-13-2002 10:46 PM
