Old 06-01-2016, 09:49 PM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Propane Detector Replacement
I haven't touched my propane detector since I bought my trailer new in the fall of 2003. Like other detectors I assume that it has a fixed life and probably needs replacement. In the mean time I have also bought a generator for emergency power and probably should consider putting in a CO detector also (even though the generator will sit outside the trailer). Obviously a separate CO detector that is battery powered (replaceable) would be cheaper to add than to buy a new CO/Propane detector that runs off of 12 volt power. Have any of you made this upgrade and if you have a combined unit what kind did you buy? I know these things are pricey over at Camping World.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-01-2016, 10:17 PM   #2
N/A , N/A
I bought this from Home Depot (have not used it yet):
http://m.homedepot.com/p/Kidde-Plug-...A&gclsrc=aw.ds
It's CO, propane, and natural gas detector. Works on AC power and 9 volt battery.
rostam is offline   Reply With Quote
Old 06-03-2016, 12:33 PM   #3
2015 30' Classic
Pleasanton , California
I'd hesitate before buying a propane gas detector that runs on AC. Often, these detectors require about 1 W or more of power for the sensor to operate correctly - which is why they are typically connected to either AC or a 12 V source. The battery backup probably won't allow the device to run much more than a few hours and if you're not connected to AC or there's an AC failure, you may not have protection.
S
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 06-03-2016, 08:37 PM   #4
N/A , N/A
S
The detector should beep when the battery is low. Still, as you mention, I think a detector connected to 12V battery source would be a better choice.
Propane detector replacement mountainborn General Repair Forum 1 10-25-2014 11:50 AM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Propane Detector Install davidz71 LP Gas, Piping, Tanks & Regulators 0 08-14-2008 08:58 PM
Propane Gas Alarm/Detector Wiring campadk Electrical - Systems, Generators, Batteries & Solar 4 05-02-2007 07:16 PM
Propane Detector Jim Tyrney Airstream Motorhome Forums 10 08-02-2005 09:55 AM
