Old 06-08-2016, 01:30 AM   #15
Long Island , New York
waldosgone, I see you replied on that older thread, so I have multi-quoted some of the earlier posters there [so they will receive email notifications about being quoted]. Hopefully they will be able to help out here. Good luck on the push north with Chinook!
Have you all been happy with your PD4655, and could you all comment on the noise issue being raised here? We are also considering this upgrade, but want to make sure the noise issue is resolved first.
Peter
Originally Posted by Steamy1 View Post
I had purchased and installed a PD4655 for our Bambi several years ago. it worked great with the two-6 volt Lifeline batteries. we could go almost 5-days boon docking, using the furnace in the morning, taking showers, LED reading lights at night, listening to Sirius satellite radio. I had purchased the PD and batteries from Randy at Best converter. The cooling fan hardly ever runs. Maybe just in boost mode after usage with the volts down to 12.06 of so.
we just recently purchased a 2015 23FB, and I wanted to replicate the Bambi system, so I purchased a PD4655, again from Best, and installed it. As soon as I connected it, the cooling fan came on and has run continuously as long as we are plugged it. Thinking the Interstates were shot from sitting on the dealers lot, I installed my Lifelines from the Bambi, which I know are good, and the fan continues to run. Called the PD tech, and they said it was a defective unit, and to return to the retailer for an exchange. Waiting on shipping and return instructions from Best. They gave me the address but no info on the shipping expense. I certainly hope that they would not expect me to pay to return a defective unit.
Originally Posted by Al and Missy View Post
With no AC power, mine was flashing. Flash rate may depend on state of charge. I don't remember what mine was doing, but it may have been flashing at a rate other than those defined in the manual.
Al
Originally Posted by mrprez View Post
I'll have to check mine to see what is going on when not on shore power.
Sorry, yes it is in Use mode all the time.
Originally Posted by KJRitchie View Post
Now that I have a 3 stage converter I leave the Use/Store switch to Use all the time except in storage. I also disconnect the battery while in storage.
So all you PD4655 owners let me know if the Charge Wizard LED is lit when not connected to shore power.
Kelvin
Originally Posted by Arcticfox View Post
Thanks for the link and answer. When you say you never touch the "use/store Switch" I'm assuming you just leave it in "USE"?
Doug
Originally Posted by switz View Post
The single stage OEM Parallax converter unit was on my list of things to replace on our new 2013 25FB International Serenity along with the GYM tires as soon as I got the unit home from the dealership in October of 2012.
While the replacement multistage unit fit as advertised, the relocation of the incoming wire connection posts on the new board required some creative efforts to gain several more inches of "loose" wire in order to make those connections under the cross frame queen bed.
Originally Posted by waldosgone View Post
Is yours silent or does it make some noise?
Old 06-08-2016, 08:59 AM   #16
waldosgone's Avatar
2015 20' Flying Cloud
Eagle River , Alaska
Thanks Peter, I didn't know they would get notifications if they were quoted. I'll keep that in my proverbial bag of tricks from now on.
James
waldosgone is offline   Reply With Quote
Old 06-08-2016, 09:34 AM   #17
Yes James that trick works even years later, unless they have toggled off their notifications in the User Control Panel. [under Quick Links at top right menu bar] Or unless they have stopped being active here obviously.
You can shorten the quotes by deleting text inside the brackets, and add ellipses to indicate . . . the deletions. This cleans up the look, but I did not have time this morning to do that, so I put my comment above all the quotes.
Also the multi-quote button to the right of the Quote button is helpful in collecting disparate people into one thread. When you multi-quote from different threads, however, you have to look under your text composition box for the site's query about including quotes from other threads. Hard to describe but pretty obvious if you try it a time or two.
Good luck.
Peter
Old 06-13-2016, 03:43 AM   #18
FYI another PD4655 installation, where I linked this thread for comment.
http://www.airforums.com/forums/f449...-a-152200.html
Hope Chinook is finding favorable winds heading north!
Peter
Old 06-13-2016, 05:42 AM   #19
James
Michael reports in that other thread that the mfg. has fixed the problem FWIW.
Hope that Chinook is finding favorable winds on the way North!
Peter
Old 07-10-2016, 04:24 AM   #20
Wondering if you got this noise sorted out, and how your trip north is going? We are considering the Progressive upgrade.
Peter
Old 07-31-2016, 12:08 PM   #21
waldosgone's Avatar
Peter
Peter,
To close out my portion of the thread. I installed the replacement unit PD sent to me while I was stopped in Seattle. The noise was still there when I plugged the trailer in but we had to press north for timing...
The more we used the trailer the noise stopped and now appears occasionally. As we're using Chinook quite a bit in Alaska during the summer this may wait to the fall/winter to remove/replace (R2 from my flying days) the PD with another unit under warranty.
I do like that we've been able to keep Chinook plugged in, in our driveway, for the last several weeks. It's nice to have the fridge ready to go after work on Friday!
I'll keep this thread in mind as I shake out the PD unit. Of note, I just sold my Parallax 7355 for $200 on eBay... effectively making this a $12.97 (plus my time) upgrade. I'd say it's well worth it to learn more about the electrical system on the trailer.
James
Old 07-31-2016, 01:43 PM   #22
2005 19' Safari
GLENDALE , AZ
Power supplies use "magnetics" in the form of transformers, toroid coils, etc., which can draw a lot of current. If the magnet wire is not securely bonded in place (called potting or varnishing), individual wire strands can vibrate due magnetic field fluctuation. The resultant sound can be humming, hissing, etc., with the frequency varying according to the the circuitry on the printed circuit board.
It's possible that there are some defective magnetics in the converter.
Old 08-03-2016, 08:20 AM   #23
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Thanks For the description. My charger was ok until Sunday when after I unplugged it from shore power the blinking LED charging light indicator still kept blinking. I'm in Yosemite right now dry camping and the light is still blinking. Has anyone experienced this?
subfan1 is offline   Reply With Quote
Old 08-03-2016, 12:20 PM   #24
Thanks James, I have been out of town and just saw this reply. Sounds like a good plan, and yes your net cost would be hard to pass up!
subfan1, hope your charger is OK, and that you are having fun in . Do you have the intstruction manual with you? Wondering what the yellow light means . . .
Happy Trails,
Peter
Peter,
James
Old 08-03-2016, 12:36 PM   #25
steverino's Avatar
2010 27' FB Flying Cloud
Ivins , Utah
V
steverino is offline   Reply With Quote
Old 08-03-2016, 10:26 PM   #26
TahoeStream'n
subfan1's Avatar
Thanks for the suggestion on the manual yes I have the user guide but is of little help in terms of troubleshooting. The blinking LED light is only supposed to blink when connected to shore power and is off when dry camping.
Old 08-05-2016, 03:00 PM   #27
TahoeStream'n
subfan1's Avatar
Just an update to my previous comment. I called customer service at PD this morning and asked service rep regarding blinking green LED without shore power and they told me that was normal. The part that still puzzles me is that same indicator light is used to determine charge rates when connected to shore power. Again she said it was normal.
Old 08-05-2016, 05:23 PM   #28
Thanks for the update.
Progressive Dynamics PD4655 Converter/Charger thinairflyer Airstream Classifieds 0 04-23-2016 05:42 PM
Progressive Dynamics 4045 Converter soldiermedic Batteries, Univolts, Converters & Inverters 18 07-15-2011 06:10 AM
Progressive Dynamics Inteli-Power 4060 Power Center 68 Overlander Commercial Listings 0 01-21-2011 11:24 PM
Bad PROGRESSIVE DYNAMICS INTELI POWER 45A mountainman1 Batteries, Univolts, Converters & Inverters 5 09-08-2010 05:54 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
