Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-28-2006, 06:39 AM   #1
dufferin
dufferin's Avatar
Profile:  2007 28' International CCD
on the go , Canada
Images: 11
Unhappy Problem with univolt ?
Hi,
there is my problem.
I did plug my AS on the 120, without the battery, as I wanted to run the 12v lights and the furnace, but nothing happened, and I thought that I could do it that way.
So I did plug the battery, and then I was abble to run the lights and the furnace, for few minutes.
The battery went low pretty fast.
So I thought I have to let it charge...
After a complete day and night the battery is still lowm and if run one light it goes down.
How can I make sure that the univolt is working well...
Is the problem is just because of the battery...
My AS is a Overlander 1975, with the original univolt, and I don't have the manual, and on my other AS (overlander 1972) the univolt is brand new, and the manual of that could help me, but the fact is that manual is in my 1972 AS, and the 1972 AS is not home.
Thank you for your help,
dufferin is offline   Reply With Quote
Old 04-28-2006, 07:31 AM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Sounds like the univolt is not working. Do you have shore power to the outlet that the univolt plugs into? Is the polarity correct? You should be able to hear the Hummmmmm of a working univolt. My 75 has an indicator on the exterior rear of the trailer that indicates if the polarity is incorrect.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 04-28-2006, 07:43 AM   #3
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
actually I've just tried to check the outletm and being that close I heard the hummm, quite soft.
I checked all the fuses, I don't have any 12v from the univolt, I'm running with the residual charge of the battery...
Old 04-28-2006, 08:11 AM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
If I had a dollar for every sentence I've read with the words "Univolt" and "problem" on this website........................
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 04-28-2006, 08:11 AM   #5
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Just because the Univolt hums, doesn't mean it is working.
Put a voltmeter across the output wires of the Univolt and you should have ~13.8 volts. The transformer could be receiving electricity (that's the hum) but the diodes or capacitor could be shot. You could have it fixed at a motor shop, but I recommend replacing with either an Iota or WFCO converter.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 04-28-2006, 08:20 AM   #6
Pick
Pick's Avatar
Images: 36
Mine is getting replaced with an Intellicharger this weekend. I am reading 29 volts AC, at the battery terminals, with the battery connected!
Lots of Hot Sauce!
Air # 283
Old 04-28-2006, 08:24 AM   #7
azflycaster
Phoenix , Arizona
Images: 60
Are you getting the 91xx or 92xx series?
Richard
Old 04-28-2006, 08:32 AM   #8
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
get rid of it
hi- I agree, get rid of the 30+ year-old dinosaur and go for a new intellicharger or similar unit.I too was fooled by the HUM (and the PO, who, giving his sales pitch to me, said "sure it works- hear it humming?") and wasted time trying to make it work. Into the dumpster with the 40-lb. anchor, into the coach with a feather-weight, quiet new converter! -tim
tphan is offline   Reply With Quote
Old 04-28-2006, 12:36 PM   #9
dufferin
dufferin's Avatar
on the go , Canada
Images: 11
thank you,
I know what I have to do now...
So if I want to change for a new one, should I purchase a 30 amp or more...
thank you again
Old 04-28-2006, 02:20 PM   #10
Pick
Pick's Avatar
Images: 36
AZ, got a 40 amp 9100 series. Have not got the Charge Wizard, yet.
Lots of Hot Sauce!
Air # 283
Old 04-28-2006, 04:38 PM   #11
ibedonc
ibedonc's Avatar
Profile:  1983 31' Excella
Caldwell , Texas
boat anchor
I just got my 9260 this morning , will be connecting it tonite , even though my boat anchor , battery cooker still works
ibedonc is offline   Reply With Quote
Old 04-28-2006, 08:31 PM   #12
26.982 amu
Profile:  1972 29' Ambassador
1968 22' Safari
Tyler , Texas
My Intelipower 9160 with Charge Wizard is sweet! The installation was swift and the operation is noiseless (especially important, since the unit sits under the bed).
26.982 amu is offline   Reply With Quote
Old 04-28-2006, 08:53 PM   #13
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
One last thought for you, and some may think it is silly, yet it is so simple it can be overlooked. Many people in the past, realizing the univolt cooks batteries, put on/off switches behind the couch to keep that from happening, yet allowing the shore power to stay plugged up to allow use of 110 volt appliances. When the batteries went low, they would turn on the switch, and the univolt would charge the batteries. Does yours, by chance, have one of those switches?
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 04-28-2006, 10:25 PM   #14
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
That's a great point steelbird. Actually the idea originated from the humming noise at night from the old Univolts transformer but I'm sure there were people even back then realizing it might be overcharging their battery too. I read in one of the owner manuals that the option was to reduce the noise while sleeping.
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 10:24 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
test
