07-08-2019, 08:34 PM
#21
2016 22' Sport
2020 25' International
Clinton
, Land of Purple Mtn Majesty,Montana
Originally Posted by rmkrum
Consider a lift table to save your back. The heavy duty one can lift higher than the light duty one. Measure the height of your vehicle before you buy one.
Would you give more details on the item you are referring to? Is this a device that you could load heavy items up and onto a pickup bed?
07-09-2019, 12:32 AM
#22
2007 22' International CCD
Corona
It’s a hydraulic lift table available at Harbor Freight. I don’t have other details available other than they have two versions. The one with higher weight capacity also can lift that weight higher.
07-09-2019, 09:07 AM
#23
2019 30' International
Maitland
Predator generator from Harbor Freight
Thanks for all the responses. I decided to buy the Predator 3500 because it was on sale, and because I would prefer a single generator than having to worry about connecting two 2000 watt generators to run the air conditioner in my AS. (I am aware of the Easy start which might allow me to run an air conditioner on one 2000 watt generator). I purchased the Predator 3500 for $700 on sale at HF and with a further discount coupon, compared to over $2,000 for a similar Honda (which also won't fit under my truck bed topper). I did buy an extended warranty for a year.
I also considered the HF pneumatic lift tables. The smaller model lifts 500 lbs up to 28", and the larger model lifts 1,000 lbs up to 34 1/2". My Denali tailgate is 36 1/2" off the ground, so the larger unit would probably suffice. The real problem is that you need to lift the generator about 1 foot off the ground just to get it up on the table of the larger lift unit. I happen to already have a crane/winch which fits into my trailer towing receiver, and can lift and swivel over the bed of the truck. I'm a deer hunter and have used this crane to lift deer into the bed of my truck, or to let them hang so I can field dress them. I should be able to lift the generator into the truck bed that way. Once in, its stays there until the end of the trip. If that doesn't work, I may reconsider the lift table.
Thanks again for the suggestions and comments.
07-09-2019, 01:01 PM
#24
2000 25' Safari
Davidson County
, NC Highlands County, FL
Originally Posted by Gneff
Thanks for all the responses. I decided to buy the Predator 3500 <<snip>>
If your experience is like mine has been, you will be happy with your purchase.
It is very important with this generator, or any generator for that matter, that the carburetor is drained of fuel any time the generator is not going to be used for an extended time. The fuel passages within the carburetor are extremely small, so easily clogged if fuel evaporates leaving a residue. Pay special attention to this. The instructions in the manual cover this in more detail.
Please report back your experience, good or bad.
Thanks!
Alan
07-10-2019, 08:56 PM
#25
2019 27' Globetrotter
McHenry
Add SeaFoam if you use gas to stabilize fuel
Since generators don’t get used every day it’s a good practice to add 1 oz. of SeaFoam per gallon of gasoline to stabilize it for up to 2 years: https://seafoamsales.com/early-seaso...-tune-up-tips/
As others have stated, its best to run the fuel out of the carb but sometimes not practical or you forget. I found SeaFoam to be better than StaBil or other fuel additives.
Enjoy your new genset!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
07-11-2019, 05:48 AM
#26
1993 30' Excella
Fowlerville
, Michigan
Rec Fuel
Does anyone else run recreational fuel (93 Octane ZERO ethanol) in their generator? Any noticeable difference, doesn’t matter what brand generator...
07-11-2019, 06:36 AM
#27
Lin
, Ne
87 octane unleaded with no ethanol is 1st choice.
07-11-2019, 06:49 AM
#28
2012 25' FB International
Trent Woods
, North Carolina
Gasoline with ethanol has never been a good choice, especially for small engines. The energy of the fuel is less and the ethanol allows water in solution which can affect soft hoses, seals and other components more common in small engines than cars. Yeah, it costs more, I suppose because of lower production.
I used to see the affect on my truck, a 10% boost in fuel mileage with no ethanol. Of course it was not cost effective, but with a 26 gallon tank, it gave me a little more reach.
Larry
07-11-2019, 07:00 AM
#29
Maitland
I've started the break-in period on the Predator generator, and have a question that I can't find a direct answer to in the Harbor Freight manual - Do I need to add fuel stabilizer if I'm running 89 octane ethanol-free gasoline? I can easily get ethanol free gasoline a a Wawa station near me.
07-11-2019, 07:04 AM
#30
2018 23' Flying Cloud
Punta Gorda
HF 2000W Generators
Just some observations on my personal needs and use and selection of two HF 2000W generators.
Living here in SW FL wife and I have to consider that maybe we might have to run away from some nasty weather. (Emma passed directly overhead) I too also have a bad back and required a weight limit on lifting into the truck bed then moving it around in the bed for use and/ travel. As most of our trips are to sites with hook ups the generators would not be used on a regular basis so did not want to carry around that weight on a regular basis and loading and unloading of a heavy unit could be hazardous to my well being.
Our truck is equipped with a tri-fold tonneau cover so I am able to stand up and position stuff in the bed. The HF 2000W units will fit under the closed cover even with a parallel kit installed.
I have had the units since Sept of 2018 and with a little care and following the oil change schedule they have been reliable. (Note: When I purchased the two units I only covered one with the extended warranty.)
Here is some tech stuff you might already know about:
Units are 47 lbs. empty of fuel
Fuel tank is 1.26 gals
Run time at 50% load is 6.5 hours
Each unit is rated at 2000W surge and 1600W run (2X in parallel)
In summary would I do this again? Absolutely. In my opinion the units can be configured as needed, have been reliable and remarkably quiet and are easy to maintain, especially in the changing of the oil department.
Cons: The units so not have any gauges or display for run hours or output for amps/volts. Would be nice to have, but at this price point I can work around this.
Wish you well in your search and that you get the best compromise that fits your needs the best.
07-11-2019, 07:23 AM
#31
Tampa
Around here, Ethanol free gas is 89 octane because it doesn't contain octane robbing ethanol!
Wa-Wa has an ethanol free pump, but it's expensive. ($3.06?)
Before a trip, I dump any left over gas from by can into the truck, then refill with ethanol free.
07-11-2019, 07:33 AM
#32
2000 25' Safari
Davidson County
Octane (resistance to engine knock) is increased by adding ethanol.
What is lost by adding ethanol is BTUs (combustion energy).
https://mnbiofuels.org/media-mba/blo...-for-beginners
from ^^^^
"In terms of its octane rating, ethanol has a rating of 113. As mentioned above, fuels with a higher octane rating reduce engine knocking and perform better. Also, almost all gasoline in the US contains 10 percent ethanol. When you mix 10 percent 113 octane ethanol with 85 octane gasoline it increases the octane two points to the normal 87 octane most consumers use. So the higher the ethanol content, the higher the octane. The octane rating for E15 (15% ethanol) is 88 octane and E85 (85% ethanol) is 108 octane."
Alan
07-11-2019, 08:23 AM
#33
2000 25' Safari
Davidson County
<<snip>> Do I need to add fuel stabilizer <<snip>>
Stabilizer is needed only if the fuel will be stored for a long period.
But it will not hurt anything if you add it.
ps:
covered on page 8 in my HF Predator manual, under "Checking and Filling Fuel".
Alan
07-12-2019, 08:57 PM
#34
1993 30' Excella
Fowlerville
, Michigan
Ninety Four
Very true, and let’s not forget ethanol burns cooler as well, lowers EGT’s. Doesn’t make much difference in a 200cc single cylinder generator but it does in my 90’s Turbo’d Japanese car. E85 all the way in that thing.
I wasn’t implying ethanol was bad when I asked about recreational fuel. Here in Michigan the only place I can find recreational fuel is Sunoco and it’s 94 octane.
07-12-2019, 09:19 PM
#35
Salem
, Oregon
jobjar I added a run time meter to my generator. They are small and easy to install. Believe I paid about $10.00 on Amazon
Dave
07-12-2019, 09:38 PM
#36
2017 19' Flying Cloud
Calgary
, Alberta
4 problems with Ethanol blended gasoline, summarized highlights from this article are below:
Article on Ethanol Fuels
1) It is corrosive to certain materials in fuel systems, including some rubber compounds and the zinc and aluminum alloys used in carburetors.
2) Dries out rubber fuel system components. This leads to cracking and brittle fuel lines, floats, seals and diaphragms.
3) Hygroscopic – it attracts water. Forming a chemical mix that causes corrosion.
4) A solvent in older engines, dissolving varnish and other deposits which are carried to carburetor or injection system where they can plug small orifices.
In 2001, under pressure from the farm lobby, seeking a ready market for corn – used in the manufacture of ethanol – the U.S. Environmental Protection Agency (EPA) approved gasoline with 15 per cent ethanol content, but prohibited its use in small engines and other power equipment due to the potential damage.
At that time, the U.S. Department of Energy reported that gasoline containing the allowed 15 per cent ethanol caused corrosion of metal parts, including carburetors, degradation of plastic and rubber components, harder starting, and reduced engine life in small engines.
07-12-2019, 10:07 PM
#37
Corona
Which is why I bought a dual fuel inverter generator and plan to run it ONLY on Propane...
07-13-2019, 05:26 AM
#38
Punta Gorda
Thank you for the information. Just saw a You Tube about installing one. Looks like I will be putting another item in the jobjar.
07-13-2019, 07:24 AM
#39
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Wen generator
https://www.amazon.com/WEN-56200i-20...52871130&psc=1
I have a pair of these with the parallel connection kit.
They work well. The only oddity is they seem to start promptly when I remove the fuel cap. After they start I put the fuel cap back on & they run fine. Only other downside is they don’t have a fuel shutoff so you can run the carb dry when done and ready for storage. However I keep stabilized no-ethanol gas in them.
I believe they’re Yamaha powered. They are very quiet, relatively speaking.
$430 ea on Amazon. For a pair with a parallel kit, you can get by for less than $1K
07-13-2019, 07:33 AM
#40
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Converted both of our Honda 2000 generators to propane only
