Old 06-28-2010, 06:42 PM   #15
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Originally Posted by mello mike View Post
I'm curious what others have done with the old, two-wire 120v wiring. Did you rip this out and install new 3-wire romex or install a new ground wire at each outlet and update these outlets for 3-prong? My 30amp inlet and fuse panel are grounded but the individual outlets are still two-wire.
tough one, I started out stringing an insulated ground since I had the bottom skins out replacing floor, but then found a few splices in the wall without boxes that were pretty baked, and I ended up removing a few more interior rivets and running new romex, including a circuit for a/c. Both have their benefits, I agree if things test ok and you're not pulling things out, leave as is and add a ground if you can (make sure its insulated so the skin doesn't become part of that system), but if you are opening up for reno, replace the wire makes more sense.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Forums 101 - posting, accounts, basics Janet H Forum Admin, News and Member Account Info 25 07-06-2016 01:39 PM
'School me' on the basics - Electric 101. NJtoNC General Appliance Topics 34 10-16-2010 10:21 PM
HELP!!! Airstream Basics. brelize Buyer Guidelines 13 06-02-2010 10:46 PM
'66 Tradewind Basics 66 Tradewind 1959-69 Tradewind 2 09-08-2004 07:30 PM
Electrial surge charge controller WayWard Wind 1997 - 2004 Bambi 0 05-05-2003 08:28 PM
