Old 02-04-2016, 09:40 AM   #1
2013 19' Flying Cloud
evergreen , Colorado
Power switch blues
On 2013 19' FC, I noticed my toggle power switch (inside red light by door, doesn't turn off when boo docking & trying to save batteries...... So, continuos depletion of batteries. Do I need to replace switch or is something else wrong?
masterfly is offline   Reply With Quote
Old 02-04-2016, 10:15 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine never turns off if AC power is being applied. I do get a loud click from the area of the junction box (?) in the front of the trailer when cycling the switch.
MICHAEL
Old 02-04-2016, 11:29 AM   #3
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Notoriously bad job of labeling confusion by JC. The Red Light merely indicates DC to the coach - either the batteries are connected, you have solar, or are plugged into shore power. Battery connect/disconnect is primarily indicated by the audible click when the switch is toggled as Michael states.
If you have no shore power and no solar, clicking the battery disconnect should cause the Red Light to go out. If it doesn't, suspect the switch.
The Ice Man is offline   Reply With Quote
Old 02-06-2016, 04:29 PM   #4
Thanks; I was talking boondocking , not shore power. My OEM Interstate batteries need to be replaced, so I'm hoping that might be the issue.
Old 02-07-2016, 09:41 AM   #5
richw46's Avatar
Lexington , Kentucky
I have solar and when I set the switch to 'Store' the red light goes out. There is an audible click for the power relay.
If you're not on shore power and the light stays on, there's an issue. If you toggle from Use to Store and back is there a click' There should be a relay energizing and de-energizing. If you don't hear that then either the switch is bad or the relay is stuck.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-07-2016, 10:23 AM   #6
1974 Argosy 20
Kooskia , Idaho
The switch light itself is an LED and consumes very very little power, probably under 3 mA. (three thousands of an amp) so it should not be an issue in boondocking.
The Radiator Blues swebster Mechanics Corner - Engines, Transmission & More... 46 08-01-2013 07:47 PM
Over the hill in style - b-day blues Janet H Our Community 30 01-24-2012 05:22 AM
Underbelly Blues hex Belly Pans & Banana Wraps 3 10-24-2002 08:47 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
Polishing Blues. TBKP's Overlander Cleaning, Stripping & Polishing 19 10-12-2002 07:57 AM
