Old 01-01-2018, 06:42 AM   #1
2018 25' Flying Cloud
Wynnewood , Pennsylvania
Power on Sequence
Is there a prescribed sequence on hooking up at a site, i.e. plug exterior power 1st, then turn power switch on in trailer?
TJPL1970 is offline   Reply With Quote
Old 01-01-2018, 07:02 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Turning off the breaker of the campground power post is the common procedure.
This keeps the shoreline plug and outlet from arcing, and being pitted and damaged over time.
Turn it on after the the plug is seated in the outlet.
Congrats on the new trailer.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-01-2018, 07:54 AM   #3
Byron Center , Michigan
I donít have a firm sequence that I follow, but Iíve included a tester based on forum advice and always use it first to make sure the pedestal power is wired correctly. They make testers that are built into external (in line) surge protectors that make it even easier, and give you the added benefit of protection. I do like JDís suggestion of breaker off, plug it in, breaker on.
YippieKiYa is offline   Reply With Quote
Old 01-01-2018, 08:07 AM   #4
Power up sequence
At what point do you turn on the trailer "USE" switch, before you hook up to shore point? Also on powering down, "USE" switch off 1st?
Old 01-01-2018, 08:40 AM   #5
2007 22' International CCD
Power on Sequence
USE switch only controls 12 volt power from your batteries. Turn it on when you need to use any appliance or lighting that needs 12 volt power. Fridge, water heater, furnace, vent fans, etc all need 12 volt power. In most Airstream trailers, the USE switch has to be on to charge your batteries as well.
The only thing involved between the 120 volt shore power and your 12 volt system is the convertor/battery charger.
Old 01-01-2018, 08:44 AM   #6
Mollysdad's Avatar
Attach umbilical cable to trailer.
Breaker off.
Plug in Surge protector.
Breaker on. Read the code to verify the outlet.
Breaker off.
Plug in trailer.
Breaker on.
Old 01-09-2018, 06:37 PM   #7
2011 22' Sport
Portland , Oregon
I installed a hardwired surge protector/power monitor, it avoids the problem with plugging in while "hot" because there is no load present until the power is inspected. I just plug it in and walk inside, if the power isn't "on" I then look at the display of my power monitor to see the fault (e.g. reversed polarity, missing ground, etc).
SilverHouseDreams is offline   Reply With Quote
Old 01-09-2018, 07:25 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My "sequence" is to be sure the power is on and working before I unhook the trailer from the TV.
Overhead cabinet Tambour re-install sequence bweldon Cabinets, Counter Tops & Furnishings 2 02-17-2014 04:46 PM
Renovation sequence of events (or plan of attack!) kdenault General Repair Forum 2 08-18-2011 05:28 PM
Heater firing sequence for a '62 Bambi. W. Higgins LP Gas, Piping, Tanks & Regulators 16 11-04-2006 08:38 AM
Changing Sequence of Posts....How do I ?? route66 Forum Admin, News and Member Account Info 2 08-13-2004 04:38 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
