Old 08-05-2016, 01:21 PM   #1
clinton , South Carolina
Power jack issues
Does anyone know if there's a fuse for the power jack? I can't seem to get power to it, but I know it works. Wondering if there's a blown fuse somehow. Thanks! I have a '92 Excella.
TheLulaRoed is offline   Reply With Quote
Old 08-05-2016, 02:37 PM   #2
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
When mine acts up, it's almost always a grounding issue. Try loosening and then tightening the three bolts that hold the jack to the a frame. Make sure to support the trailer tounge before loosening the boltsThe jack only receives ground from the trailer frame. In a pinch I have used the ground from a battery box connected to one of the 3 above mentioned bolt heads.
1973Argosy is offline   Reply With Quote
Old 08-05-2016, 02:37 PM   #3
Gainesville , Florida
I think there's an inline fuse between the jack and the battery? Anyone?
Old 08-05-2016, 02:51 PM   #4
1976 31' Sovereign
Oswego , Illinois
Wink
There are numerous posts and threads as to inline fuze. plus grounding Yes there is one and usually tied into break away swt. but sometimes wired direct to hot source.
Old 08-05-2016, 06:26 PM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
On my '15 the fuse is inline wired to one of the positive battery terminals, right down where the jack is bolted onto the tongue.
Caffeinated is offline   Reply With Quote
Old 08-07-2016, 09:05 AM   #6
Thanks for the suggestions! It's been a busy couple of days but I'm going to try these solutions later today.
I did find where the wire was pretty severely cramped (and showing through/rusted) where it goes under the propane tank cover.I cut out the bad section and spliced the wire back but that didn't fix it. I'll look at the grounding issue and let you know. Thanks again!
Old 08-07-2016, 10:15 AM   #7
Missouri Valley , Iowa
If you had a bare wire, there is a good chance the inline fuse is blown.
Dan
Farmer Dan is offline   Reply With Quote
Power jack getting power. OffTheCouch Electrical - Systems, Generators, Batteries & Solar 11 01-01-2016 11:39 AM
Issues/Problems with 6.7 Power Stroke? rbs Tow Vehicles 15 01-05-2014 10:26 PM
AC Power issues RobC Sprinter and B-van Forum 2 10-01-2012 01:24 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
