Old 05-30-2009, 05:55 PM   #1
2003 34' Classic S/O
PORTSMOUTH , Virginia
Power cord: Where to find
The power cord which came with my 34' 2003 s/o is only 20' long and very heavy. I need at least 50' which will either extend from the "monster", or one with a male fitting which will fit the trailer receptical. Either 50 or 30 amp. Anyone with suggestions?
STERELLIE is offline   Reply With Quote
Old 05-30-2009, 06:03 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Ebay again
However, look under boat parts and accessories.
Old 05-30-2009, 06:09 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
30 Amp RV Extension Cord, 50' - $65.99
Old 05-30-2009, 08:10 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Or Camping World: RV Electrical Cords and Adapters Camping World - Electrical Cords - Camping World
Old 05-30-2009, 08:28 PM   #5
1971 29' Ambassador
Leonardtown , Maryland
Buy one already assembled. I purchased the parts and made one and still cost me close to $60.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 05-30-2009, 09:03 PM   #6
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I did some shopping at Camping World yesterday and they had some extentions but do not know how much they were. What I did buy was reasonable.
AirHeadsRus is offline   Reply With Quote
Old 05-30-2009, 10:19 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
25' Extension cord.
Hi, I bought a 30 Amp 25' RV extension cord for my trailer. I bought it at Camping World. So far I have not needed to use it, but it's there if the time comes.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-31-2009, 04:16 AM   #8
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
I would do the same make your own IF it was not sealed plugs which is better in outside weather.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 06-03-2009, 04:14 AM   #9
Thanks everybody, but still not resolved. I bought a 30 amp 50' cord from a West Marine. I now need a 4 prong female to a twist 30 amp male adapter. I'll check with the electrical outlets. Perhaps Hubble will carry something. Camping World dosn't. The quest goes on...
Old 06-03-2009, 05:46 AM   #10
Kevin245's Avatar
Which One?
RV's have a special plug designation. It sounds like the cord you have does not have the TT designated plug/recepticle. Perhaps the easiest thing to do would be to see if you can pick up a TT cord, and return the one you cuurrently have.
You may be able to find an adapter like you're looking for, if not, you'd likely need to make one. Do you know what desigantion your connection is?
L14-30, L18-30, Non-Nema 30...
I would check McMaster-Carr. They are not the cheapest, but they seem to always have the one thing no one else carries.
Regards,
Kevin
Eleanor Roosevelt
Old 06-03-2009, 05:45 PM   #11
1971 29' Ambassador
I did have sealed plugs I sealed them, I do this for a living on aircraft. If you want to find fault with my input look somewhere other than cabeling.
_________________
Rebee - WBCCI #1325
Old 06-03-2009, 07:40 PM   #12
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Your local Wal-mart will have 30ft 30A RV extentions.
Michelle TAC MT-0
Sarah, Snowball
Old 06-03-2009, 08:26 PM   #13
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
STERELLIE...I'm confused. My 2007 trailer has a 30 amp, 3 prong locking male receptical on the trailer. My Airstream supplied power cord has a 30 amp, 3 prong locking female connector on the trailer end of the cord and a 30 amp 3 prong male RV plug that fits into the campground power supply. If this is what you have you can purchase a 50' 30 amp RV power cord with a 30 amp 3 prong female RV connector and a 30 amp 3 prong male RV connector and use it in line with your existing cord. The only problem is that the connection between the cords is not weather proof. When I need an addional length of power cord I use a 25' boating cord with a 30 amp 3 prong locking male connector on one end and a 30 amp 3 prong locking female connector on the other end. I connect the 30 amp 3 prong male RV plug on the Airstream supplied RV cord to the campground power supply and connect the trailer end of the Airstream cord's 30 amp 3 prong female locking connector to the new boating cable's 3 prong locking male connector . I installed a "Sealing Connector" between the original Airstream supplied RV cord connector and the boating cord connector so I have a weather proof connection between the cables. I then plug the 30 amp 3 prong female locking connector on the boating cable to the trailer's 30 amp 3 prong locking male receptical. Attached pictures are from the Marinco Electrical Group's website.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 06-03-2009, 11:50 PM   #14
Salem , Oregon
Images: 18
A better way.
Hi, 2dabeach. Although I have already purchased an RV 30 Amp extension cord and as I have stated, I never have had to use it yet, I like your solution better. Thank You for posting this information with pictures included.
2005 Safari 25-B
Power Cord replacement, 1959 Tradewind plowboy Electrical - Systems, Generators, Batteries & Solar 16 12-31-2013 04:03 PM
Replace Power Cord ZacharyTX Electrical - Systems, Generators, Batteries & Solar 4 12-28-2008 04:04 PM
Battery to AC power cord??? Jim Casavant Batteries, Univolts, Converters & Inverters 9 07-22-2007 03:46 PM
power cord end Rick's73 Electrical - Systems, Generators, Batteries & Solar 6 07-29-2003 08:34 AM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 05:49 PM
