Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-28-2003, 10:51 AM   #1
Rick's73
Rick's73's Avatar
Profile:
Question power cord end
my '73 Overlander has a 15amp breaker inside. What I would like to know is since by dogbone (the reducer from huge plug to regular 110 household plug) is shorting out, could I just cut off the big male plug end on the cord and replace it with a household male plug end? If I do this will I need an amp reducer to plug into a 30 amp power supply (because I have a 15 amp breaker inside my trailer)?
Rick's73 is offline   Reply With Quote
Old 07-28-2003, 11:01 AM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
The cord is a 30 amp cord, therefore you could safely put an plug up to a 30A plug on it. A regular 110 household plug would be just fine.
The 30A to 15A adapter is ordinarily not a really good idea since there is a weak link (the regular 110 household plug) between the 30A breaker in the campground supply and the cord. Lots of people do it, though, especially older popups and get away with it.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-28-2003, 12:02 PM   #3
Rick's73
Rick's73's Avatar
Profile:
power cord end
I need to put a new end on my power cord. What kind of male plug end should I get?
Rick
Old 07-28-2003, 12:11 PM   #4
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
You will have to read the fine print, but the larger home improvemnt stores sell a replacemnt end for around 10 bucks US.
You need to be sure it say recreational vehicle use on it, otherwise you have a 220 Volt end and the color codes may not match.
Another option is to buy a new 30 amp extension cord from the local camper store and cut off the female end and wire it into the main panel on the trailer. This leaves you with a female end that you can add a 15 amp plug to for a dogbone, just remeber not to cut it too short!
If you are not comfortable with the process or electricity in general get a pro to do it. The cost is minimal compared to the damage or injury that can occur if not done properly
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 07-28-2003, 06:32 PM   #5
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I use one too, just not with the A/C running!
I am eventually going to have a 30a line pulled through the conduit I have going to my detached garage.
Old 07-28-2003, 06:59 PM   #6
Rick's73
Rick's73's Avatar
Profile:
thank you Silvertwinkie
Rick
Old 07-29-2003, 09:34 AM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Some owners that have had the 30 amp plug go bad, have opted perhaps for a better solution than changing just the plug.
They purchase the Canadian 36 foot cable, and use it to replace the original 25 foot cable.
Provides an extra 11 feet of cable (lord knows, we all needed an extra couple of feet cable or so once in a while), along with a new cable.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Power Cord plowboy Electrical - Systems, Generators, Batteries & Solar 13 02-23-2004 06:54 PM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 06:49 PM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 06:29 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 07:16 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
test
