Old 08-09-2015, 09:11 PM   #1
1972 25' Tradewind
Willow Park , Texas
power converter
I have a 72 Airstream. Can I use a 7355 inverter in this older trailer? I have 1 air unit on it. If so, is there a wiring diagram online somewhere? that is a Parallux
hebetter is offline   Reply With Quote
Old 08-09-2015, 09:14 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You are running your air conditioner on an inverter? I don't think that is good...
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2015, 09:48 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Just looked this up. It's a converter, not an inverter. Looks like it should do the trick, although people on this forum don't seem to care for Parallax. Take a look at the Boondocker series or Intellipower as alternatives.
DryFly is offline   Reply With Quote
Old 08-10-2015, 02:08 PM   #4
1972 25' Tradewind
Willow Park , Texas
Thanks. I'll check out the other converters. This is my first airstream. Someone stole the converter and the stove, but the A/C works.
Old 08-10-2015, 03:02 PM   #5
1974 Argosy 20
Kooskia , Idaho
The Parallax 7355 is a single stage converter/charger which is used in most newer Airstreams. It is not a very good unit in that it only charges at one voltage, not three as is best for batteries. As mentioned, it is not an inverter, it is a converter/charger 120 volts to 12 volts.
You can use it but it is far from optimum. Progressive Dynamics 9255 is a good one, and other 3 stage converters are available. Randy at bestconveter.com is a good phone source for information and products.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
Power Converter on 92 Land Yacht DaveJ Electrical - Systems, Generators, Batteries & Solar 0 06-16-2004 12:55 PM
Power converter "fuse" rfield54 1997 - 2004 Bambi 0 09-02-2003 02:26 PM
