Old 09-21-2010, 11:15 AM   #1
2010 19' Flying Cloud
Gardendale , Alabama
Power Breaker will not reset
My breaker is tripped and will not re-set. The breaker box is located beneath ref. and has 3 breakers. The one with the test button will not reset. Can anyone help?
gdixon1126 is offline   Reply With Quote
Old 09-21-2010, 11:34 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
That`s the gfi breaker,it is either detecting a ground fault or is a bad breaker.You can dis connect the outlet from the breaker and see if it will reset,if it won`t,you need a new breaker.If it will reset,you need to start taking apart the receptacles it feeds and checking them out. Dave
easyride is offline   Reply With Quote
Old 09-21-2010, 02:09 PM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
GFCI breakers do not like moisture....you may disconnect the wires
leaving the GFCI breaker and see if it will reset with nothing connected
to it. If yes, then proceed outward.....if no then replace the breaker.
New or old these can be tempermental......persistance will pay.
kennethowens is offline   Reply With Quote
Old 09-21-2010, 05:04 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Uh... first try this. Push the flipped breaker to OFF, then reset to ON.
When it flips it goes to sort of a middle position - ask me how I know
Old 09-21-2010, 06:11 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
before you replace ground fault, check to see that you have a good source of electric and ground from house power. use circuit tester at house plug, then on circuits not on ground fault.
how do you reset the inverter dsrtgrls Batteries, Univolts, Converters & Inverters 2 02-19-2021 04:30 PM
Can't reset circuit breaker evamcmahan Electrical - Systems, Generators, Batteries & Solar 2 03-21-2010 08:54 AM
Thermal Breaker Reset n2916s Electrical - Systems, Generators, Batteries & Solar 6 10-11-2009 04:00 PM
Electrical Newbie with circuit breaker that won't reset...help please! Kerina Electrical - Systems, Generators, Batteries & Solar 13 05-04-2008 09:18 AM
Power Jack Breaker Size Rick Alston Electrical - Systems, Generators, Batteries & Solar 4 08-31-2004 11:46 AM
