Old 06-12-2019, 02:38 PM   #1
AirstreamCSH's Avatar
2016 25' Flying Cloud
Huntington , New York
Positive Buss Bar on 2016 FC 25FB
During the course of figuring out how to route the wires and locate the equipment for a DIY solar installation, I needed to understand the positive buss bar configuration. Should I connect my solar controller to this bar and if so, where? This post is for the next person searching for information about the bus bar and wanting to know what it does.
The Electrical Diagram on page 8-19 of the 2016 Users Manual describes this block as having Type 2 Breakers on the bottom row and lists the amperage's going left to right as 50A, 50A, 30A and 20A. A Type 2 Breaker will trip when the amperage going across it exceeds what it's rated to handle. For sake of conversation, I'll call this the amperage threshold. The breaker will not reset until the amperage drops below the amperage threshold. The practical impact of this knowledge is that the wire gauge that you connect to each of these studs needs to be able to handle a current flow equal to, or greater than, the amperage that each breaker is rated for. Otherwise you will have a situation where the breaker won't trip before the wire melts.
From left to right on the bottom row, the studs are connected to:
6-gauge wire feeding battery
6-gauge wire feeding the left side of the battery cutoff switch
10-gauge wire feeding the 7-way trailer connection box
12-gauge wire feeding the Break-Away switch
On the top row, where all the studs are connected by a common copper bar, there is only one cable attached and that is the LP/CO2 detector. Since that bar doesn't have a Type 2 breaker, anything connected to it would have to be fused in-line somewhere.
One of the things you can take away from all this is that at the very least, the 7-Way trailer connection box, the Break-Away switch and the LPT detector aren't disconnected when the Battery Cutoff Switch is engaged. Just to complete the list, since the Electric Hitch Jack and the Inverter are connected directly to the battery positive terminal post, those two items also aren't disconnected when the battery cutoff switch is put into STORE mode.
FYI
OH ... Some people connect the Solar Charge Controller to the top copper bus bar and others just run a cable directly to the battery. Either is OK. The logic for that decision is left to a different post.
Name:	2016 FC 25FB Positive Buss.jpg
AirstreamCSH is offline   Reply With Quote
Old 06-12-2019, 03:19 PM   #2
2007 22' International CCD
My solar charge line is simply connected to the input side of the use/store relay. One of these days I’ll add a cutoff switch and a fuse.
Old 06-12-2019, 06:44 PM   #3
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
My solar is connected to the copper bar side of the positive busbar.
ID:	343159   Click image for larger version
2017 Flying Cloud 25FB (Miles) 266 nights (6/16/19) 35,133 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's, TM66 TPMS
2019 F250, 6.7 Power Stroke, 4x4
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Connecting to the positive bus bar marter Electrical - Systems, Generators, Batteries & Solar 6 09-15-2018 12:43 PM
50 amp buss fuse line install which one? Mx468 Batteries, Univolts, Converters & Inverters 4 01-09-2017 08:14 PM
grey bar and red bar compound capt ken Cleaning, Stripping & Polishing 4 10-02-2013 11:17 PM
Aluminum to Copper buss bar Adair Batteries, Univolts, Converters & Inverters 10 09-19-2007 06:53 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
