Old 02-26-2015, 12:19 PM   #1
2005 22' Interstate
san clemente , California
portable surgeprotectors??
Does it make any difference if the portable surgeprotector is attached between the pedestal and extension cord or the extension cord and the trailer/van connection???
Thank you for your interest in helping this fairly new retiree.
unifreck is offline   Reply With Quote
Old 02-26-2015, 12:26 PM   #2
Britbat's Avatar
1975 27' Overlander
LaVale , Maryland
I'm also interest in the replays to this as I'm thinking of shortening my shore line and hiding the surge protector in the trunk of our '75 Overlander due to posts I've see about theft of them.
Britbat & the Shiny Beast
Britbat is offline   Reply With Quote
Old 02-26-2015, 12:35 PM   #3
SteveH's Avatar
Common Sense , Texas
It makes no difference, but they make the same protectors designed to be mounted inside your unit, and hard wired into place. That's what I did, and so I know it's always in place, and always protecting my appliances.
Regards,
Steve
Old 02-26-2015, 01:07 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Doesn't make any difference. Only advantage to portable one is that it is easy to replace if it gets toasted. The hard wired ones, not so much. FWIW I have never had one stolen in 15 years of using them, and have never heard of one being stolen in any campground I have ever stayed in.
Aaron
WBCCI #XXXX AIR #2495
Old 02-26-2015, 03:14 PM   #5
SteveH's Avatar
Just more of my opinion here, but I installed the permanent unit because I didn't want to have to haul out yet another device every time I hooked up to utilities, especially something that needed to be protected from rain, and possible theft.
With the water hose, water filter, power cord, and most times either the satellite dish or the cable hookup, felt like that was already too much.
Name:	surge protector.jpg
Regards,
Steve
Old 02-26-2015, 05:39 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
One of the benefits of a plug-in style unit is the ability to still be operational IF it does it's job and blows itself up!
If you hardwire the unit in to the trailer and it senses a surge and self immolates, you have to wire a bypass to be able to still use the trailer. With the portable unit, simply unplug, move to another site and plug back in until you can get a replacement.
I have never heard of a theft in 15 years or RVing, but they do make a large plastic hasp as a means of deterrent. If someone wants anything bad enough, they will find a way. At least this will usually make the casual thieves think twice and look elsewhere.......
Old 02-26-2015, 05:44 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use the portable plug-in type. I considered the wire-in type, but was concerned that we would be out of business if it had to do its job. As Lew said, if our plug-in blows out, we can move to another site and we're back in business.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 02-26-2015, 06:45 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Portable here also... I didn't scrimp, IMHO low voltage protection is the problem thats more likely, auto shut down will save all that 'needed' stuff we take along.
Old 02-26-2015, 06:46 PM   #9
SteveH's Avatar
Actually, the "wired in unit" is quite a bit more sophisticated than a protector that simply "blows itself up".
Basically, it's a voltage, current, and frequency monitor that closes a relay when it sees that everything is correct. Any time it senses voltage too high, to low, frequency off, current too high, or a ground fault, it disconnects the relay and turns off the power to the RV. When conditions return to normal, it will reenergize the relay and power returns.
Regards,
Steve
Old 02-26-2015, 07:15 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
And if it gets a zap from lightning or a severe voltage spike it is toast. There is no functional difference between the portable and the hard wired units that I am aware of, other than the ease of replacement of the portable unit and the ability to easily bypass it.
Aaron
Old 02-26-2015, 07:47 PM   #11
lewster's Avatar
Aaron
Exactly!
Old 02-26-2015, 08:38 PM   #12
SteveH's Avatar
Lightning can and will destroy anything.
The reason I installed the unit was because we had an air conditioner fan motor burnt up from low voltage at a park in Colorado last summer. This unit would have prevented that damage.
Regards,
Steve
Old 02-26-2015, 09:41 PM   #13
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I use a portable surge guard but whether portable or installed permanently I believe it's worth the money to protect things in the travel trailer. I have recently purchased a new TRC Model 34830 surge guard.
Ron
Ron A is offline   Reply With Quote
Old 02-27-2015, 12:29 AM   #14
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
ME TOO
But then I have a spare ... well it's for the washer and dryer.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Portable Generator Marks Generators & Solar Power 38 11-04-2017 08:36 PM
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Portable washing machine Sneakinup Washer/Dryer & Dishwashers 11 06-04-2009 06:54 PM
Portable Jump Starter joshua32064 Batteries, Univolts, Converters & Inverters 6 10-12-2003 12:13 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
