Old 08-20-2019, 10:42 AM   #1
1967 30' Sovereign
Leavenworth , Kansas
Portable Solar Panel
I have a Zamp portable solar panel and had 12.5 volts than I pluged in the solar panel and after 45 minutes it read 13 volts. I thought that meant that the solar panel was working. A Zamp tech guy said my panel was toast with these reading. For $140.00 he will send me all the parts I need. What about the photo cells are they also worn out? What is wrong with 13 volts?
Thanks for any suggestion,
Dajon
dajon is offline   Reply With Quote
Old 08-20-2019, 04:46 PM   #2
Chelsea , Maine
If you’re saying that’s the voltage at the battery terminals, you’re okay. It’s going up, meaning you are charging the batteries. It should go up more.
If that’s the voltage your panel is putting out (not connected to battery) at the panel leads, in full sun, then something is amiss.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 08-20-2019, 05:59 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Dajon
Take a photo of the Zamp controller connected to the battery after two hrs in full sun.
Volts, Amps and ah.
1 120w panel
ID:	350031   Click image for larger version
ID:	350033   Click image for larger version
HITC....🌥
Wiring of the Portable Solar Panel Plug chugchug Generators & Solar Power 17 01-28-2018 09:57 PM
Can a portable solar panel be added to a factory solar system? larry9000 Generators & Solar Power 7 10-14-2017 04:35 PM
Recommendations for portable solar panel kit? jagzoo Generators & Solar Power 37 03-06-2017 08:28 PM
Portable solar panel table timzog Generators & Solar Power 7 01-29-2016 02:39 PM
Portable Solar Panel Battery Charger Mrjkq Electrical - Systems, Generators, Batteries & Solar 10 08-09-2015 08:22 AM
