Old 10-30-2011, 06:10 PM   #1
1974 25' Tradewind
Berryville , Virginia
Polarity light
I am doing over a 74 trade wind LY . I am wondering whether the polarity light is still necessary ? Next if it is how do you get the Neon pilot light out to replace it .Anyone have a source for this? I have it out of the frame just can not get it out of the white housing.
batt is offline   Reply With Quote
Old 10-30-2011, 06:19 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is the light bad? It should only come on if the polarity of the power you are connected to is bad. If everything is correct, the light will be off. To get to it on your TW, you will have to remove the junction box that is located under the bathroom sink by working through the small cabinet door.
I use a small polarity tester that I plug into the campground plug before I plug in. I have found one bad plug in the last 6 years.
Richard
Old 10-30-2011, 06:49 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Richard, do you know how to reconnect a polarity light? We've got one in the electrical compartment (of course), but the wire is disconnected.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 10-30-2011, 06:56 PM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
The two legs of the lamp connect to the 120 volt neutral and the 120 volt ground. If the neutral is hot (reversed polarity) the light will illuminate.
If you are powered from a generator, this will not work because there is no ground.
Richard
Old 10-30-2011, 06:58 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The $5 ones like above give you more data that the polarity light but the polarity light will check at 30 amp outlet that the above one will not unless you have a 30 amp to 15 amp adapter dog bone, which I don't.
Old 10-30-2011, 07:10 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
It's just a few bucks at CW, good investment. I like to check before I plug in.
Worldwide Merchandise Company - 30 Amp Male to 15 Amp Female Round Adapter - Electrical Adapters - Camping World
Richard
Old 10-30-2011, 08:59 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Humm. Next time we're around, I want you to look at ours. It seems only to have one wire leading from it. Could be that attachment to ground is simply attachment to the body of the rig? If so, then I would just attach the wire to negative/neutral, I guess.
Lynn
WBCCI 21043
Old 10-31-2011, 07:48 AM   #8
1974 25' Tradewind
polarity light
I have been doing a rebuild and since it is a 74 I felt I may as well replace it while it was out and easy to work on. Any one have a source ?
Old 10-31-2011, 08:57 AM   #9
The old neon polarity light bulbs are almost a thing of the past.
If the original one is still working, save yourself some headaches, and keep on using it, since finding a replacement is almost like finding tubes for old radios.
Old 10-31-2011, 06:08 PM   #10
1974 25' Tradewind
Thanks for the tips ,So I should just purchase a tester and drop the wiring of the polarity light. Seems redundant in view of todays modern testers which are cheap and exact.
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
