02-17-2007, 05:26 PM
Cyclist
2007 28' International CCD
Windermere
Plugging in At Home
I have 20 amp circuits at home. Trailer needs 30 amp to run the big stuff. Can an electric dryer outlet be adapted?
02-17-2007, 05:28 PM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
Typically, electric dryer outlets are 220 volts.
Welcome to the forum!
02-17-2007, 05:34 PM
1978 31' Excella 500
Goose Creek
, South Carolina
I leave my unit plugged in at home on a 20 amp. It will power everything excluding the old armstrong Ac unit.
02-17-2007, 05:58 PM
2003 22' International CCD
Kiln
, Mississippi
Your trailer operates on 120V (commonly called 110V) - the dryer circuit is 240V (commonly called 220V). So - do not use that outlet for your trailer. A new trailer outlet and surface mount box will cost under $25 form Home Depot, 10 guage wire is not that expensive per foot and you can have a length under 75 feet without any problem with voltage drop. The 30 amp breaker will cost under $10. Now - if you have to hire an electrician, that's where your cost will rise - but this is a simple addition if local codes allow you to do your ownn electrical. If they don't - mount the box run your wires and have the breaker ready - minimize the work an electrician has to do and just have him pop in th breaker.
As stated above - you can get an adaptor for your trailer shore cable and use a regular household circuit - just don't use your AC or plug in too much stuff.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
02-18-2007, 04:09 AM
Cyclist
Windermere
Plugging in At Home
Thanks for the advice.
Will check out supplies at Home Depot...... with final work by an electrician.
02-18-2007, 07:09 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
henw
please make absoulutely sure you tell your electrician that he is working on a 120 VOLT 30 AMP CIRCUIT!
a few members have had their trailers damaged after electricians have looked at the receptical and ASSUMED it was 240 volt!
you might get a stupid look from your electricain but it is better to be safe than sorry!
john
you call them ferrets, i call them weasels.
02-18-2007, 07:16 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Another 20 amp guy here I do have a 30amp 120v circuit for traveling salesmen and fellow Airstreamers to use . But my unit is only plugged into a 20 amp circuit unless I need to run the A/C.
Aaron
WBCCI #XXXX AIR #2495
02-18-2007, 08:15 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
There is a way to cheat a little bit when it comes to plugging in at home. You can take the refigerator out of the mix by going into the the outside access box, unplugging from the trailer electrical system and plugging into an extension cord that goes to a house outlet that is not on the same circuit as the rest of the trailer. Even though I have a 30 amp outlet set up at the house, I still sometimes use this trick when I am when I using the A/C and a lot of 110 stuff in the Airstream.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-18-2007, 08:30 AM
Hernando
, Mississippi
Everything considered, it is best to run a separate circuit...either DIY or hire an electrician. It solves a lot of problems. I ran a 30 amp circuit off my shop (200 amp service) to an outside RV plug. Works Fine.
Rgds,
Scott
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
02-18-2007, 09:18 AM
2002 30' Classic
East Central
, Alabama
henw
I agree with others who post it is best to run a separate circuit dedicated to the RV. Finally after several years of not having the comfort of running the AC when cleaning or preparing the camper, I finally ran the 10 gauge wire, installed a RV receptacle and had an electrician to install the 120 volt, 30 amp breaker. Probably one of the best things I could have done.
Curt
02-18-2007, 05:03 PM
Cyclist
Windermere
Thanks all. I am calling the electrician in the a.m. Should be an easy set up as the main box enters house right next to where trailer parked. 120v, 30 amp.
03-24-2007, 10:17 PM
Yakima
Rgds,
Scott
I agree, its best to bite the bullet and have an electrician run some wire from your 200 amp home box with a 30 amp plug designed for your trailer. Then ya know its done the way it should be and if your house burns down MAYBE your Insurance Co. won't blame it on you?
I am going even further. I am purchasing a Honda EU6500is. I am using it for a house backkup also. I will mount it in the back of the truck on a HIWAY PRODUCTS gorilla slide. It holds 2000# and you just slide it out...with the genny on it and ...all is good. There is a table hoist that I am looking at. I will lift 600# with a foot pump to bed height so I don't have to lift it in and out of the truck. When I was a young buck the 256# Honda would have been nothing to lift in the back of the truck......but thats why my back is bad now.
03-25-2007, 06:34 AM
Naples
I use one of those hydraulic table lifts almost every day to load and unload heavy roof airs and other weighty parts into my service van. They ROCK!
lewster
03-25-2007, 06:37 AM
Naples
one more thing..............
Don't forget to add a transfer switch to yoiur main breaker box if you intend to use your Honda as a house back-up generatator. They are required in a lot of locations, and just make sense as the best safety feature when running a gen-set for your house.
lewster
03-25-2007, 08:51 PM
1984 31' Excella
Broken Arrow
, Oklahoma
Plugging in at home
Does any body know the commercial name/number etc for the 30 amp 110v RV recptacle and the larger 50 amp recptacle?
(Please excuse spelling)
Beginner
03-25-2007, 09:01 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
beginner,
the 30 amp is nema# TT30-R for the receptical and TT30-P for the plug
the 50 amp is nema# 14-50R for the receptical and 14-50P for the plug
this is a good page that explains it, scroll down. RV Wiring
john
03-26-2007, 04:46 AM
1984 31' Excella
Broken Arrow
, Oklahoma
Plugs/Recp
Thank You Sir
Beginner
08-03-2009, 04:57 PM
1976 31' Sovereign
Dallas
I have a power cord adapter that plugs into the standard 120 V / grounded outside wall plug on the side of my house. The other end plugs into the 25 AMP AS power cord plug.
I think it's a standard RV item.
It's plenty of power to run everything in your AC except the air conditioner.
You may also want a water pressure regulator if you hook up to city water, they're cheap only about $7.00 at WalMart / RV Stores etc.
As for the sewer hookup ----------- aren't you right next to your house, can't you go inside for that?
08-03-2009, 06:02 PM
1966 24' Tradewind
Oak View
Sorry for such a stupid question, but how do I know how many amps are coming from my house? I just brought my trailer home and I have a heavy duty electrical extension cord plugged into my outside patio outlet. There is a panel in my trailer that wants me to pick the ingoing AC amps.
Carol
08-03-2009, 06:27 PM
2002 25' Safari
Dewey
A standard house plug is 15 amps. It will look like this:
It might be 20 amps, and it would look like this:
Richard
