Old 11-10-2015, 08:56 AM   #57
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
A/C outlet..
Originally Posted by cclarkego View Post
OK, I have no AC and I keep my life cool with little fans here and there.
Now, I have a small microwave in the garage that I want to bring in.
I checked post #23 in this thread again, I'll try to do the math on everything to see if it looks OK. I have not yet gone out to get the RV box yet.
What happens if I hook up the microwave and turn it on tonight and I figured something wrong?
Does my trailer explode in flames?
This is perhaps outdated by now..
I picked up my RV outlet box at a reputable Electrical Supply business..(in NH)
For the cover, switch and proper outlet rating..(30 amps..) The entire box cost over 60$..It' been 6 yrs since I bought the box..So, that figure might be off by now..Btw, it even has a lock loop feature to prevent abuse..(theft of service)
Good luck~!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 11-27-2015, 04:46 AM   #58
East Bridgewater , Massachusetts
Question about the receptacle. RV receptacle? Does anyone have a picture to post of the female and exterior box? Have my FC-25' arriving in Jan and want to prep a plug and waste disposal pipe into my septic.
renrutdraw is offline   Reply With Quote
Old 11-27-2015, 08:28 AM   #59
1974 Argosy 20
Kooskia , Idaho
Home Depot and Lowe's generally cary them. Just be sure it is the 30 amp 120 volt two slant and one D shaped ground socket that RV's use.
Old 11-27-2015, 08:39 AM   #60
Gainesville , Florida
Any rv supply place should have one. My AS dealer did.
Old 11-27-2015, 10:15 AM   #61
mapleton , Utah
see post #16 for correct receptacle , TT30-R looks just like the common dryer outlet but is rated and marked for 30A 120V RV service. Less likely to be miswired, at least if your electrician can read
tim
rumrunner is offline   Reply With Quote
Old 11-27-2015, 10:30 AM   #62
2007 22' International CCD
I can assure you, based on other posts on the forums, and personal experience, that electricians DON'T read. They just do what they always do. Double check the outlet with a voltmeter before you plug in! You don't need to hit your AS with 220 volts instead of 115!
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 11-28-2015, 02:50 PM   #63
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Got everything at Lowes, about $50.
Installed myself.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 11-28-2015, 03:28 PM   #64
Also check that the polarity is correct, please!
Old 11-28-2015, 04:19 PM   #65
Neatly done...😄
KE4GNK/AE
Old 11-30-2015, 10:28 AM   #66
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Here's a link to Amazon for receptacles alone or with box: http://www.amazon.com/s/?ie=UTF8&key...l_1nhmsv8ftc_b
The ground is on the top and the the 2 holes for the hot and common lugs are in a V shape on the bottom of the receptacle.
There have been posts on the Forum in the past where electricians did it wrong. They probably don't install many of these and they may mindlessly go into clothes dryer mode and think they are 240 v. with 2 hot wires and not 120 v. with one hot wire. Having installed an RV receptacle several years ago, they do feel like a dryer or even a stove receptacle, so a thorough mind cleaning is required before installation. I bought it at a hardware store where the salesperson didn't know what I was talking about and I had to look hard to find a dusty box with the receptacle I needed.
Gene
Gene
Motor Home Gun Laws winner On The Road... 26 08-17-2009 02:45 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
Home Page Photos ViewRVs Forum Admin, News and Member Account Info 1 09-09-2002 03:20 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
