Old 03-25-2007, 08:51 PM   #15
1984 31' Excella
Norfolk , Virginia
Images: 11
Plugging in at home
Does any body know the commercial name/number etc for the 30 amp 110v RV recptacle and the larger 50 amp recptacle?
(Please excuse spelling)
Beginner
Beginner is offline   Reply With Quote
Old 03-25-2007, 09:01 PM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
beginner,
the 30 amp is nema# TT30-R for the receptical and TT30-P for the plug
the 50 amp is nema# 14-50R for the receptical and 14-50P for the plug
this is a good page that explains it, scroll down. RV Wiring
john
you call them ferrets, i call them weasels.
Old 03-26-2007, 04:46 AM   #17
1984 31' Excella
Norfolk , Virginia
Images: 11
Plugs/Recp
Thank You Sir
Beginner
Old 08-03-2009, 04:57 PM   #18
1976 31' Sovereign
Dallas , Texas
I have a power cord adapter that plugs into the standard 120 V / grounded outside wall plug on the side of my house. The other end plugs into the 25 AMP AS power cord plug.
I think it's a standard RV item.
It's plenty of power to run everything in your AC except the air conditioner.
You may also want a water pressure regulator if you hook up to city water, they're cheap only about $7.00 at WalMart / RV Stores etc.
As for the sewer hookup ----------- aren't you right next to your house, can't you go inside for that?
stanwilder is offline   Reply With Quote
Old 08-03-2009, 06:02 PM   #19
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Sorry for such a stupid question, but how do I know how many amps are coming from my house? I just brought my trailer home and I have a heavy duty electrical extension cord plugged into my outside patio outlet. There is a panel in my trailer that wants me to pick the ingoing AC amps.
Carol
cclarkego is offline   Reply With Quote
Old 08-03-2009, 06:27 PM   #20
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A standard house plug is 15 amps. It will look like this:
It might be 20 amps, and it would look like this:
Richard
Old 08-04-2009, 02:53 PM   #21
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Thanks Az,
So it must be 15 amps. Now next question...
Am I OK running 4 small fans and Dometic frig with heavy duty extension cord (I think about 50') from that house outlet to trailer 3 prong adapter plug to big electrical trailer connection to trailer? That's a mouthful...
Old 08-04-2009, 03:25 PM   #22
1974 Argosy 26
Hamilton , Montana
30 amp vs 20 amp
This past weekend was spent at grandson's baseball tourney and set up in front of a friends house who happens to be a retired electrician. I had to use my 50 Ft. extension cord to make it to the 20 amp plug at his garage. I happen to have a separation in the outer jacket of my extension cord at the plug so he was able to clamp his ampmeter around the black wire. My 26 Ft. Argosy pulled 3 amps with the refer on and 13.5 amps with the dometic AC going full load. I wish now I would have turned on all the lights to see if that would exceed the 20 amp rating. I have been plugging in to 20 amp at home and run the AC and keep the refer cold for weekend getaways. Its hard to check amperage draw unless you have the right equipment ( and a ratty cord)!
Montique is offline   Reply With Quote
Old 08-05-2009, 02:11 PM   #23
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Originally Posted by cclarkego View Post
Thanks Az,
The short answer - Depends........
Check your fans for a plate that has information on power requirements such as 120V 2amps - add up the amps and check to make sure it's the operating amps and not the startup amps. Then check your fridge information plate or manual. Add that to the fan total. That should give you the max draw for your load - keep in mind you may be operating other unknown electrical items such as the power converter or tank monitors, etc.... There are calculators online that tell you the drop in power for a cord over some distance. Look one of those up and that will tell you the power you have at the end of the plug by the trailer. It should exceed the draw amount.
I have added the trailer box to a 30amp breaker at my house - very easy to do with common tools. I recommend doing that for safety.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-05-2009, 02:17 PM   #24
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I used a 30 amp 120v, RED DOT CODE KEEPER setup for the RV outlet..
What's nicer is, if you can put in a regular 120v gfi outlet too..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-05-2009, 03:23 PM   #25
StingrayL82's Avatar
San Angelo , Texas
Images: 37
The POs of our house had electric and water put in to the RV garage. The circuit breaker at the main box is 30a, however the receptacles at the garage are 15a each (we have two receptacles). When we add the 15a adapter to our 30a plug, we are able to use our A/C. Is it possible to replace the two 15a receptacles with one TT30-R receptacle, or does it need to be completely rewired?
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 08-05-2009, 10:56 PM   #26
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Plugging in at home
Mike
What is a trailer box?
Carol
Old 08-06-2009, 05:56 AM   #27
Images: 59
Yes, you should be able to replace two 15a outlets with a 30a if there is a 30a breaker in the main panel. Make sure the cabling coming from the 30a breaker is at least #10 AWG all the way to the new 30a plug.
Old 08-06-2009, 12:58 PM   #28
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Carol
Available at all home supply big box stores.
It's the same 30amp plug you would use at the RV park so no new cables. Just make sure when you add it you get a permit and/or a licenced electrician to inspect/install one for you using the correct wiring and breaker in the main box.
Motor Home Gun Laws winner On The Road... 26 08-17-2009 02:45 PM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 08:31 PM
Home Page Photos ViewRVs Forum Admin, News and Member Account Info 1 09-09-2002 03:20 PM
I finally got it home.... Chuck On The Road... 15 07-03-2002 11:11 AM
