Old 08-18-2019, 09:04 PM   #1
2019 - 33' Classic
RickyNelson's Avatar
2019 33' Classic
Grand Junction , Colorado
Plugged in - help - no shore power
I am at a KOA in Boise. Plugged in to 50 amp, surge protector shows ok, red light on power cord on, but not registering that I have shore power.
I basically rebooted, unplugged and replugged. Anything I can do now?
Thank you!!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
RickyNelson is offline   Reply With Quote
Old 08-18-2019, 09:08 PM   #2
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
Have you checked the main circuit breaker on the power panel in the trailer? I know where it is in the 30' Classic but not the 33'. Your owner's manual should point you to it.
Just in case they are the same, in the 30' there's a wooden panel below the wardrobe on the left. Pull off the wooden panel and you'll see another plastic panel underneath. Circuit breakers are behind that panel. You'll want to try resetting the 50amp breaker.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin (sold)
2020 25' Globetrotter Twin (inbound)
2017 F250 4x4 6.7 max tow Platinum
mikeinca is offline   Reply With Quote
Old 08-18-2019, 09:08 PM   #3
2019 30' Flying Cloud
Homosassa , Florida
Make certain you have the cable connector turned firmly to the right and the screw ring that holds it un place tight also. Check all inside breakers
Tater is online now   Reply With Quote
Old 08-18-2019, 09:11 PM   #4
2019 - 33' Classic
2019 33' Classic
I made sure the cables are firm and connected. Where is the main circuit breaker? Would that be by the fuses?
Grand Junction, CO
2019 Classic 33
Old 08-18-2019, 09:29 PM   #5
2019 - 33' Classic
2019 33' Classic
Found it and I had a couple circuit breakers tripped. Not sure why?
Thank you mikeinca and Tater!
Grand Junction, CO
2019 Classic 33
Old 08-18-2019, 09:34 PM   #6
mikeinca's Avatar
2018 30' Classic
You're welcome.
Sometimes just the act of hooking up will cause a breaker to trip if the connection to the trailer isn't made cleanly. The best way to do it is to make sure the breaker on the pedestal is off, hook up the trailer, and then throw the pedestal breaker. Anyway, safe travels!
Old 08-18-2019, 09:37 PM   #7
2019 - 33' Classic
2019 33' Classic
I have to say I had a moment of panic. Everything has been smooth sailing, but this is how you get to learn about your own AS!
Thanks again!
Grand Junction, CO
2019 Classic 33
Old 08-18-2019, 10:18 PM   #8
2007 27' Safari FB SE
Forest Grove , Oregon
Originally Posted by mikeinca View Post
You're welcome.
To again support the above and make sure the message is not lost:
Turn off the breaker at the post. Connect your electrical, then turn on the breaker. Yes this does wear the breaker....etc.....but this is not your house (except that I do this in my house 30 amp trailer connection figuring a new breaker every 3 years or so is cheap maintenance cost) so take care of your equipment and do this at every campsite.
It does require an additional campsite connect step of making sure the breaker is off before you connect, yet gives fewer issues in the end.
Just my approach and opinion.
bweybright is offline   Reply With Quote
Old 08-18-2019, 10:22 PM   #9
2019 - 33' Classic
2019 33' Classic
I really appreciate it bweybright!
Grand Junction, CO
2019 Classic 33
Old 08-19-2019, 06:58 AM   #10
Homosassa , Florida
Glad you got it fixed. Safe travels.
Old 08-19-2019, 08:31 AM   #11
Mollysdad's Avatar
Excellent.
I use a surge protector, so my routine is this. Confirm the breaker in the pedestal is off. Plug in the surge protector. Flip breaker on and read the voltage and E-code. Flip breaker off again. Plug trailer cord into surge protector. Flip breaker back on.
Mollysdad is online now   Reply With Quote
Old 08-19-2019, 08:51 AM   #12
2019 27' Globetrotter
Salem , Oregon
One more thing. If you do not already have a EMS (electrical management system)/ surge protector I would recommend you get one. Here is what I have and most of the people on this forum recommend. If you don't want the bother of another item they also make a hard wired version.
https://www.google.com/search?source...31.yTpZFeoFYqQ
This is the Progressive Dynamics PTS 50 X
Dave
NoResults is offline   Reply With Quote
Old 08-19-2019, 09:33 AM   #13
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
I had the most embarrassing incident at an RV park where the same thing happened that you described. I contacted the campground manager who sent a maintenance person who verified everything was fine at the pedestal. I was baffled and extremely concerned since it's a vintage trailer. Then I noticed a wet ring where the line from my trailer was plugged into my heavy duty RV extension cord. On closer examination I realized my dog had peed there. I went in and checked the breaker in the closet. Yep. Tripped.
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
Blu_Hwy_Lady is offline   Reply With Quote
Old 08-19-2019, 10:35 AM   #14
Mansfield , Texas
Also remember to turn off the breaker at the pole before disconnecting, saves the connectors from arcing.
HubbyBear77 is offline   Reply With Quote
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
Battery Switch on if Plugged into shore power RICKBETTY Sprinter and B-van Forum 22 07-28-2017 12:13 PM
Battery percentage low when plugged to shore power NotStock Sprinter and B-van Forum 17 05-20-2017 08:20 AM
Shore Power-Unplug OR Plugged In? tfbeitz Electrical - Systems, Generators, Batteries & Solar 7 06-13-2013 05:19 AM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 01:10 PM
