Old 05-22-2008, 12:36 AM   #1
2007 27' Safari FB SE
redmond , Oregon
plugged in
Just moved our 07 safari to covered storage. we have power at the storage site ,what is the common wisdom on winter/full time plugging in the unit. we are fairly dry, central oregon high desert. should we have a dehumidifier, space heater, or just keep water lines dry in winter and no heat? also if some heat what abour vermin?
rashton is offline   Reply With Quote
Old 05-22-2008, 06:29 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hi Ashton,
Considering you are in the dry, high desert of central OR, I would properly winterize the unit (I know it gets really cold there) by draining the water lines and then filling the system (less the water heater by using the bypass system) with specific, RV anti-freeze for water systems. I would NOT trust simply draining and air-flushing the system, as residual water in your valves can and will crack them in the cold without anti-freeze.
Plugging in will keep your battery charged, but the OEM converters that Airstream uses are only single stage units that can overcharge your batteries if left on for extended periods.
Plus, you don't want the chance to freeze your batteries if they are in a low state of charge, so the alternative to getting a 3-stage charger (or connecting one externally to the batteries) is to remove them and keep them in your garage on a trickle charger.
Other than cleaning the unit before putting it to sleep, you should be good to go.
In FL when I store my CCD for the 'winter' I have the opposite problem of keeping the interior free of mold. It doesn't freeze here, but gets very humid, and I use a couple of small marine heaters to keep the air dry and convection currents flowing!
Old 05-24-2008, 01:26 PM   #3
redmond , Oregon
plugged in
lewster , thanks for the info r ashton
Old 05-24-2008, 01:38 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
A small automatic charger is a good idea. Check from time to time to see that your batteries are just staying up and not going dry.
Don't know about trailers, but I know that people who leave their boats in the water leave a light on in the bilge to give off a little heat and keep things dry. Might think about that.
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
Plugged in 24/7 Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 21 12-04-2006 10:55 AM
Can I leave it plugged in?? KeithCheri Electrical - Systems, Generators, Batteries & Solar 14 10-05-2006 02:10 PM
Question - Keeping Trailer Plugged In kamadeca Electrical - Systems, Generators, Batteries & Solar 5 05-08-2006 12:28 PM
electric humming when it's not plugged in AnnZ3 Electrical - Systems, Generators, Batteries & Solar 4 10-27-2004 06:27 AM
