Old 08-20-2012, 09:13 AM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Plug Question
This plug is in an RV now, not very familiar with the 4 prung plugs so we need some help here please.
the main box is set for 30 AMP but this seems to be a 50Amp plug or this is just an old 30A plug?
I found this to compare but not sure..
50 Amp 4-prong Straight Blade Male Plug NEMA 14-50-RJBP1450 at The Home Depot
thanks again
ID:	166241   Click image for larger version
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 08-20-2012, 09:26 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The 30A 120V RV-use plug is 3 prongs, not 4. I agree, that looks like a 50A plug in the picture. *IF* it's wired correctly, it could supply your trailer if plugged into a 50A outlet, but I would want to determine that it's wired correctly or that the trailer wiring had been upgraded to properly handle 50A service before I plugged it in.
Here is a useful site with lots of info about RV electrical systems. Here is a link directly to the 30A page which has pictures of 30A plugs and receptacles.
David
Old 08-20-2012, 09:34 AM   #3
Southwestern , Ohio
To second DKB_SATX post above, the plug shown is more commonly used to connect to a 50 Amp, 240 Volt circuit. A standard 30 Amp RV outlet is wired to 120 Volts.
The previous owner may have put this plug on the cable--connected to only one side of the line to get 120 Volts--in order to plug it into a clothes dryer or arc welder outlet he happened to have handy. But make sure before you plug it in!
Nuvite-F is offline   Reply With Quote
Old 08-20-2012, 09:38 AM   #4
1973 31' Sovereign
2007 20' Safari SE
Hi Guys
Well based on the fact that the main distribution panel is set up for 30Amp I'm assuming that is still a 30AM connection from a 50A plug,
I guess we need to open it so see if there is 3 or4 wires..
2 chronicles 7:14
Old 08-21-2012, 02:20 PM   #5
1973 31' Sovereign
2007 20' Safari SE
DKB_SATX
Thanks for the link, very useful.
Nuvite-F
It seems like you were right about the connection to 1 pole.
As it can be seen in the pics only 3 wires, so is a 120V 30A ?
Got this adapter in walmart to test the electrical in case it was wired as 50Amp, would the adaptor still work or should we just replace the plug with a 3 prong 30A?
Thanks again
ID:	166358   Click image for larger version
ID:	166360   Click image for larger version
2 chronicles 7:14
Old 08-21-2012, 04:30 PM   #6
tinyhome's Avatar
Victoria , Texas
I would just change the plug head. Less then $20 at any hardware store. Yes the plug on it would work since they only have it wired to one leg, but it is being powered from a 50 amp breaker, not a 30 amp. That adapter you bought would also work fine.
tinyhome is offline   Reply With Quote
Old 08-22-2012, 08:10 PM   #7
1973 31' Sovereign
2007 20' Safari SE
Thanks for the input, we are currently looking on ebay for a good 30A plug but will try the adaptor and see ehats going on.
Most likely NuviteF was right regarding...: The previous owner may have put this plug on the cable--connected to only one side of the line to get 120 Volts--in order to plug it into a clothes dryer or arc welder outlet he happened to have handy. But make sure before you plug it in!
Thanks again guys
2 chronicles 7:14
