Old 03-22-2014, 04:45 PM   #1
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Planning 12V Circuits
Hi,
I'm getting ready to wire for the 12v circuits in my gutted Tradewind and want to make sure I think of everything. Here's my list:
Fantastic Fan Front
Fantastic Fan Back
Furnace
Refrigerator
Water Pump
Bathroom Exhaust Fan
Refrigerator "helper" Fan
12v Power Supply Outlet
Interior Lights (LEDs mostly)
12v TV
12v Radio/CD/DVD
Please let me know if I'm forgetting something or otherwise should plan for something (the Fuse Box I purchased has 12 Circuits/Fuses).
One other question: Is there a way to power the Running Lights w/ my converter so I can run the lights when parked? It seems "odd" to just tap into the Running Light wire w/ power from the converter when in theory the lights could be receiving 12v from 2 directions - the vehicle and the converter . . . which I have a similar un-educated view of the converter wiring diagram in which, in my small mind, a 12v device would be receiving 12v from the house battery and 12v from the converter . . . how does the electricity know to reverse direction and start charging the battery instead of sending 12v x 2 to a particular device?
OK, well thanks for any help/thoughts you can give me.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 03-22-2014, 04:53 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The easiest way to power up the running lights while parked is to use a jumper cable on your 7 way plug, don't recall which two terminals. But one is the power feed the other is the running light circuit. That way you can keep the circuits the way they are supposed to be.
Aaron
WBCCI #XXXX AIR #2495
Old 03-22-2014, 05:04 PM   #3
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Gauges / tank monitors?
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 03-22-2014, 05:17 PM   #4
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Exterior [entry] 12V light. I like to add a 12V charging bank, 3 slots, somewhere out of the way so folks can charge their stuff and I'm not tripping over it! I do the running lights on mine. I use one of the circuits in the 12V dist. panel, to a rocker switch w/glow lite, then through a diode for one way power, then tap into the running lite wire. On the one I'm doing now I'm adding a 12V aux plug and speaker wire jacks just in side a curbside lower hatch door for outside use.
putback is offline   Reply With Quote
Old 03-22-2014, 05:19 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Also consider...
Power Jack
External lighting
Non switched Co detector
Non switched propane alarm
Solar pre wire
Ethernet
USB bus
AV for TV HDMI
Incoming charge line from vehicle via high current diode
AtomicNo13 is online now   Reply With Quote
Old 03-23-2014, 06:12 PM   #6
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Sure, just run the wire. That's what I did (I had an extra switch that wasn't wired to anything). The risk is that if you leave the switch on while it's plugged into the tow vehicle - don't do that. I have a diode ready to wire up so that the vehicle's lighting circuit doesn't try to power my camper, but I haven't gotten around to installing it. If you want to be extra careful, use two diodes - one like I describe there, and one on the wire from the umbilical to the lights.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-31-2014, 08:59 PM   #7
Dean E's Avatar
1989 32' Land Yacht
Oakton , Virginia
Propane water heater igniter circuit?
Dean E is offline   Reply With Quote
12v
Running Additional Circuits help keep me out of trouble. Tony S Electrical - Systems, Generators, Batteries & Solar 15 03-23-2013 08:14 AM
How many 12V circuits SilverHoot Electrical - Systems, Generators, Batteries & Solar 12 09-06-2010 04:34 PM
Tracing 12v Circuits, Shorts...First Steps fotochop Batteries, Univolts, Converters & Inverters 27 02-27-2010 07:58 PM
Correct size fuse for 12V circuits FLYNCLD Batteries, Univolts, Converters & Inverters 7 04-23-2009 05:39 PM
12V circuits dmadam Electrical - Systems, Generators, Batteries & Solar 7 04-07-2004 03:03 PM
