Old 12-16-2005, 05:05 PM   #1
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Pinout for '01 F250 trailer connection
HelllllllP!
I am having a problem trying to get the various lights to work on my '69 Sovereign. I thought I just had a bulb out on the right rear (turn signal and brake light) Everything else was (keyword WAS) working. I changed the bulb in the right rear and that didn't help. Cleaned and respliced all wires to the RR tailight socket. Didn't help. Tried to figure out the connection from truck to trailer. Cleaned the connections, took apart the plug ends (just the outer casings to find out which color wires were at which place, not the connections themselves) I have the whole rig out at the Ford Dealer to see if I blew any fuses or anything. I just called him and he said he fixed a frayed wire on the truck end, replaced a couple of fuses and made me a rough diagram of the pin out. I am going out to get it now. Wish me luck.
cheers, bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 12-16-2005, 06:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
As they say in showbiz, break a leg.
If you still don't have a light at the location you need, check to make sure the housing is well grounded. If it isn't, all the power in the world won't make that bulb light.
If you have a test light, securely clip it to something metal on the main part of the coach, turn on the light in question, and touch the tip of the test light to the outside base of the socket. If the test light glows, or lights, you have a bad ground.
Old 12-23-2005, 07:52 PM   #3
65 overlander's Avatar
Images: 22
Pin schematic
This is in my 65 Overlander manual. Jeff
65 overlander is offline   Reply With Quote
Old 12-23-2005, 08:40 PM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Bill, The 7 pin connection on both of my Ford F150's has a cover with the pin out imprinted into the plastic. I'm a little confused by your post. Are your truck lights not working right or the trailer lights (or both)? Ford should be able to give you the pin outs on the truck connection. You can probably find it Ford.com. I'll take picture of it tomorrow if you want and post it.
If you are having trouble with the trialer end of the circuit, you can find the pin out for that here: http://www.airstream.com/airstream/p...lug1966-81.pdf
One word of caution about this diagram. I had to go by color, not pin position as indicated in the diagram. Lift up your gaucho and try to match colors first on the running lights, turn signals and backup lights. My job was kinda tough because I only had a couple of workinh running lights and one tail light.
Good Luck and Merry Christmas!
www.nesa.org
Air No. 6427
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Lookin for answers-picking up newly acquired trailer COArgosy78 Our Community 2 09-02-2002 01:23 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
