Old 07-23-2009, 05:57 AM   #1
kstampa's Avatar
2004 28' International CCD
tampa , Florida
Images: 35
photo of 30 amp inlet on AS?
I am trying to remember what exactly my 2004 28ft CCD 30amp cord connection looks like. My AS is stored 20 miles away and I'm tryin to add a male hook-up same as my AS on a homemade trailer so I can use my same cord/generator combo. Can anybody help with a pic of where you plug your cord in your late model AS? Thanks!
kstampa is offline   Reply With Quote
Old 07-23-2009, 06:29 AM   #2
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Just do a search on the internet for a RV 30 amp outlet box to see what it looks like If I am understanding what you are after.
RLS is offline   Reply With Quote
Old 07-23-2009, 10:40 PM   #3
kstampa's Avatar
tampa , Florida
Images: 35
Thanks but that doesn't help. That only shows standard type 30 amp outlets like you hook-up to at the park. I need a photo or a NEMA reference for the type of inlet (not outlet) you plug your cord into on the side of the AS.
Old 07-23-2009, 10:49 PM   #4
kstampa's Avatar
tampa , Florida
Images: 35
doesn't it look like the end of this cord with 4 prongs?
Main Power Connect
Old 07-23-2009, 11:13 PM   #5
1992 34' Limited
Falls Church , Virginia
All -
Correct me if I am wrong, but isn't 50A the 4 prong, and 30A is the 3 prong variation....?? My recollection...
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 07-24-2009, 01:22 AM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi,
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-24-2009, 05:12 AM   #7
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
My 2007 has a Marinco which I presume is the same as on your A/S.
Check out these:
http://www.marinco.com/files/media/p...PP%2030A_7.pdf
30A Standard RV Power Inlet | Marinco
SilverCottage is offline   Reply With Quote
Old 07-24-2009, 05:20 AM   #8
Kevin245's Avatar
The standard RV plug is typically a NEMA TT series as shown below.
[edit] NEMA TT–30
NEMA TT–30 plug and receptacle. (The center hole on the receptacle is not a contact.)
NEMA TT–30 is a 30 A, 125 V recreational vehicle standard which may also be known as RV 30. It is frequently (and sometimes disastrously) confused for a NEMA 10–30. The RV receptacle is common in nearly all RV parks in the United States and Canada, and all but the largest RVs manufactured since the 1970s use this plug. The hot and neutral blades are angled at 45° from vertical and 90 degrees to each other, similar to NEMA 10 devices. The plug is slightly smaller than a NEMA 10 but larger than ordinary 5–15 plugs. The ground pin, however, is round, like those on straight-blade NEMA grounding devices. Referring to the diagram, the orientation is the same as the NEMA 5 plug and socket, with the receptacle neutral on the lower right. Due to the appearance of this plug, many people assume that it is to be wired for 240 V, but this is a 120 V device. Adapters exist with the TT–30 plug on one side and a 5–15 or 5–20 socket on the other side. When the cord is detachable from the RV an L5–30 is usually used on the RV end of the cord.
Or are you referring to something like this lockset connection from Marinco that is becoming more common.
Eleanor Roosevelt
Where oh where is the water inlet????? Hamb7 Fresh Water Systems 13 01-10-2011 07:15 PM
Need new water inlet like this! coffeydelsol Fresh Water Systems 5 06-19-2009 11:46 AM
Tank inlet Cochese Fresh Water Systems 0 10-25-2006 04:47 PM
Fresh water inlet William Ales Fresh Water Systems 0 10-11-2006 08:32 PM
