Inverter
Trace and Xantrex are the two brands I find most in the RV's I work on. If you get the inverter/charger models, they will do the battery charging for you when connected to 120VAC, provide 12VDC and have an internal auto transfer switch for when 120VAC is present.
Thay aren't cheap, but are well worth it if that's the direction you would like to take.
BTW, They are both made by Xantrax now!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/ VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
