Old 01-02-2016, 10:35 AM   #1
2011 23' FB Flying Cloud
Boca Raton , Florida
Parallax Power
My AS has a Parallax 55 amp series 7300 power supply. Is this the OEM unit?
Another question... there is a cooling fan at the back of the refrigerator controlled by a simple toggle switch. It is either on or off. Is there some way to connect it to a thermostat so it doesn't stay on all of the time?
Thanks.
bobgoldstein is offline   Reply With Quote
Old 01-02-2016, 11:11 AM   #2
NukeSubSailr's Avatar
2010 20' Flying Cloud
Surry , Virginia
I have a 2010 20' Flying Cloud and that is my OEM. My ref fan is almost never used. I thought the on position did cycle it on as needed but has not been on long enough to check it out.
NukeSubSailr is offline   Reply With Quote
Old 01-02-2016, 03:52 PM   #3
read some of the old threads on the fan issue... got it. Here in FL it's normal for the fan to run all of the time. :-)
I guess I should read more and ask less.
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Parallax Converter Replacement with Xantrex SilverGate Batteries, Univolts, Converters & Inverters 18 10-03-2009 07:49 AM
Parallax Boiled One Battery DEITZ645 Batteries, Univolts, Converters & Inverters 2 07-10-2008 07:04 AM
Parallax to Intellipower TIMEMACHINE Batteries, Univolts, Converters & Inverters 25 01-08-2008 03:29 PM
Parallax charger with temp control Pacerized Batteries, Univolts, Converters & Inverters 2 04-21-2007 06:16 PM
