Old 02-15-2015, 07:52 AM   #1
1976 31' Sovereign
Chester , Vermont
Panel gauges
Has anyone replaced the gauges and meters in the panel? I have a '74 Sovereign Int'l. I would like to upgrade . relocating seems foolish, but I would like to change it out. I would really like to see photos too, of course
Thomasmg is offline   Reply With Quote
Old 07-06-2015, 07:35 PM   #2
murfreesboro , Tennessee
Same situation here... did you find anything ??
dlang4d is offline   Reply With Quote
Old 07-07-2015, 10:05 AM   #3
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
Here is what I'm working on... I have a OLED panel now installed and you can see a very crumby video here of how it is working and what I've been playing with.
I installed grey tanks and added sensors to it but need to run the wires to the control panel when I redo the front section of the belly pan.
I just need to add the warning LED to the pressure gauge which will turn on when tanks are FULL or EMPTY depending on which tank, etc. Then I need to finish the permanent wiring and mounting it back in the panel. I will rebuild the entire panel insert as mine is a bit worn but I wanted to keep the same vintage look while modernizing it a bit!
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
'69 Safari control panel gauges Dixie722 Batteries, Univolts, Converters & Inverters 0 03-11-2014 08:13 PM
1974 Control Panel Gauges JimWeilhammer Electrical - Systems, Generators, Batteries & Solar 5 09-12-2012 08:32 AM
Gauges.. How to... FrankR Electrical - Systems, Generators, Batteries & Solar 1 01-16-2003 05:51 PM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
OPD valve w/sight gauges 83Excella LP Gas, Piping, Tanks & Regulators 1 04-16-2002 07:21 AM
