Old 08-28-2016, 08:02 PM   #29
lewster's Avatar
Naples, FL , Hood River, OR
Painless Group 27 Battery Installation
One more thing........
REPLACE THOSE WING NUTS!!!!!!
ABYC limits wing nut use to a maximum of 8 AWG for trolling motors. Stainless flange nuts will work extremely well in this application.
Lew Farber
Lew Farber...ABYC Certified Master Marine Electrician...RVIA Certified Master Tech ...AM Solar Authorized Installation Center...AIRSTREAM Solar & Electrical Specialist
Old 08-28-2016, 10:24 PM   #30
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Great advice, thanks! I have those too, will do. The wing nuts were making me nervous anyway.
Rocinante is our 2014 International Signature 27FB
Old 08-29-2016, 01:35 AM   #31
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by lewster View Post
OK folks,
Due to a comment that I made in another thread about a painless way to put a pair of group 27 batteries into Airstream's tongue mounted battery box, I decided to post a photo of an upgrade that I just finished. Don't know if anyone has posted this before, but it was one of those 'OMG' moments when it hit me a couple of days ago.
No more cutting, painting or sweating it.
Just look at the photo below and all will be revealed....
In fact, the threaded rod and spin-on retainer still work as there is room to move the batteries fore and aft against their respective walls, leaving enough space to replace the rod.
Hi, I have seen a few pictures of this installation of group 27 batteries. I'm concerned about massive arcing during the placing of the batteries in the box. Would / could it be better to install the batteries with the posts facing inward, instead of outward like in your picture?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-29-2016, 12:06 PM   #32
Rivet Slave
Rocinante's Avatar
Updated photo showing a cleaner wiring design that leaves the batteries accessible for checking and adding distilled water as needed.
Also switched to those flange nuts for the bolt terminals that Lewster recommended. Much better, as it's not possible to get wing nuts tight enough to secure big cables.
I added a flange to help the retainer bolt hold the batteries in place while distributing the pressure across more than just a bit of the shoulder of each battery. Looks better to me now.
I imagine one could install the batteries with terminals more to the center if desired. This orientation, however, allowed me to use the existing house wires without inventing any new 4-letter words. (The length of a couple of the cables was quite limited.)
I experienced zero risk of, or actual, arcing of any kind when dropping the batteries into the case as shown. Also none while wiring, as I used due care.
If you're not comfortable doing this, you are free to take another approach. No need to armchair quarterback. Also, please remember a photo is always a 2D rendering of a 3D environment and can be deceiving.
Name:	ImageUploadedByAirstream Forums1472493873.852002.jpg
Old 08-29-2016, 12:51 PM   #33
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I will be producing a mid kit for the 220 amp/hour golf cart batteries as soon as I get back to OR this summer. Watch the classifieds!!!!
The riser will not allow for full opening of the front storage door on larger FBs. I usually mount batteries under the bed in those coaches, as try are either Lifeline of lithiums.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Lew, I would be interested in this kit, do you have any ?
Doug and Cheryl
Old 08-29-2016, 02:55 PM   #34
Rivet Slave
Rocinante's Avatar
Vinnie, of Vinnie's Northbay Airstream Repair, also sells battery box extenders, in case Lew doesn't have any: http://www.vinniesairstream.com/part...ndealerid3366/ or https://www.facebook.com/VinniesNort...04542062955224 to get a look at them.
Not affiliated with Vinnie in any way, just sharing info.
Group 24 to Group 27 Batteries in my 27ft International BoldAdventure Batteries, Univolts, Converters & Inverters 8 02-26-2015 07:52 PM
Group 24 to Group 27 handn Batteries, Univolts, Converters & Inverters 2 06-07-2014 06:42 PM
Help-Group 31S vs Group 27 Battery Question trevisgardne Batteries, Univolts, Converters & Inverters 4 06-10-2009 08:32 AM
Bambi upgrade to group 31 battery? rfield54 Electrical - Systems, Generators, Batteries & Solar 0 05-17-2005 09:33 AM
Battery Group BA Sovereign 1974 - 1979 Sovereign 4 09-16-2003 10:28 PM
