Old 08-28-2010, 08:32 AM   #1
Hendrick2488's Avatar
1966 26' Overlander
Cedar Falls , Iowa
Outside outlets
I have a 28ft 1966 Overlander Twin. While checking to see if the outlets outside were working I plugged in a device, it worked, I heard a pop and both outlets outside are now dead. Everything else inside the trailer works except maybe the fridge. I noticed that the fridge and something else are actually plugged into an outlet inside the access panel. I can't find any blown fuses but don't know much about the unit because we just got it.
Can someone offer advice on what to look for or how to fix?
Thanks in advance.
Hendrick2488 is offline   Reply With Quote
Old 08-28-2010, 01:30 PM   #2
x
XXXX , XXXX
It sounds like a GFI ( Ground Fault Interupter) has tripped. Look at the outlet outside and in the bathroom. If the PO had installed a new outlet in either location it may have tripped. There should be two little buttons in between the two outlets. One is marked TEST and theother is marked RESET. Push the reset and you should have power.
wasagachris is offline   Reply With Quote
Old 08-29-2010, 05:00 AM   #3
1966 26' Overlander
Cedar Falls , Iowa
Thanks for the reply. My father-in-law, and electrician, came to see the camper and looked into the problem.
He found the circuit breakers inside the box in the bathroom, weren't tightened down in the box correctly. Although they were in the proper position, they were loose and not making a good enough connection. Problem solved.
Thanks again for your reply. Now that the electrical system works, its off to the water system. Cross your fingers. :-)
All outlets not working NicheVintage Lights - Interior & Exterior 11 09-16-2011 10:42 AM
Where have all the outlets gone - 2003 Classic. wxbuoy 2001 - 2005 Classic 8 12-07-2009 02:45 PM
12-volt outlets Steve & Susan Lights - Interior & Exterior 1 09-17-2008 06:21 AM
110V outlets cookeville34 Electrical - Systems, Generators, Batteries & Solar 2 09-17-2006 07:15 AM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
