Old 11-14-2012, 07:13 PM   #1
2006 19' Safari SE
Hayes , Virginia
Outside Electrical Outlet
After this much time I thought I knew where all the fuses are located, but....I had a radio plugged in to the outside receptical and "I" popped the fuse where the trailer is hooked up. Reset the breaker in my garage and EVERYTHING works in the trailer except the outside receptical. Where is the fuse for that receptical or could it be something else? 2006 Bambi 19' Safari SE. Thanks
mocus is offline   Reply With Quote
Old 11-14-2012, 07:32 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The outside outlet, as well as the one in the bath, should be on the GFCI breaker. In my Excella, the outlet for the converter is also on that circuit.
It can be easy to overlook that the GFCI has tripped because most of the time I don't have anything plugged into the bath outlet. The outlet in the bedroom in my Excella is there too, so that's how I usually catch it. My alarm clock goes dead.
Vaughan
Old 11-14-2012, 08:59 PM   #3
RV Fixer
wickedrevs56's Avatar
2013 Interstate Coach
Corpus Christi , Texas
Send a message via Yahoo to wickedrevs56
Indeed numerous outlets are "run through" the gfci, find it, reset it, chances are very high that is the problem. In older Firewood products we had to "reroute" some outlets because the gfci would not carry the total current loads....
wickedrevs56 is offline   Reply With Quote
Old 11-14-2012, 09:00 PM   #4
2013 25' FB Flying Cloud
Jacksons Gap , Alabama
I have the same trailer and my outside electrical outlet is connected to a GFCI in the main panel. My GFCI failed a couple of years ago and I replaced it with a standard house GFCI from Home Depot. However, if all of your other outlets are working, you may have a second GFCI receptical inside that feeds to the one on the outside. Home bathrooms are commonly wired that way so all recepticals are protected in the room. Just a thought.
Frank
Frank McFee is offline   Reply With Quote
Old 11-15-2012, 04:11 PM   #5
2006 19' Safari SE
Hayes , Virginia
Thank you all
Believe it or not, I have been working on toilet seats today and just got to the computer--I wouldn't lie. Duhhh, didn't even think about the GFCI. Will giver a look tomorrow and let you know. Thank ya'll for the advice....Tom
Old 11-15-2012, 04:28 PM   #6
2006 19' Safari SE
Hayes , Virginia
Ahhhhh
Heck, I couldn't wait until tomorrow, I had to check it tonight, You guys were right....I flipped the GFCI and walla. I wish it was like the house power panel and show red when tripped.....Oh well, hopefully, I will remember it. Thank ya'll very much. Tom
