Old 08-25-2019, 06:42 PM   #1
1970 27' Overlander
Townsend , Georgia
Outlet wiring
Anyone have any idea where the second wire goes from the outlet in bathroom in 1970 overlander 26. With the second wire attached the breaker keeps tripping in control center. Changed breaker. Capping wire and all outlets work and breaker does not trip but now battery not charging. Any help appreciated
Mglaude is offline   Reply With Quote
Old 08-25-2019, 08:51 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well it sounds like that outlet and the converter/charger are on the same circuit, so I'd venture to guess that the wire goes to or at least toward the charger/converter.
Maybe the charger is going bad and is throwing the breaker?
It's a place to start......
Old 08-25-2019, 09:02 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Outside outlet? Is the tripping breaker a GFCI breaker? Typically the bathroom, outlets near the sink, and outside are protected by a GFCI. Outside outlets often get dirt, insect nests, and moisture in them that cause GFCI trips.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-26-2019, 07:39 AM   #4
1970 27' Overlander
Townsend , Georgia
Thx guys I purchased a new boondocker converter charger and plan to replace the univolt system. I took every outlet out and checked continuities and all check out ok except for that one wire which goes to back . If I put back in series it trips breaker.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
wiring a new 30 amp outlet gparker Electrical - Systems, Generators, Batteries & Solar 22 03-25-2010 08:07 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
