Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-23-2006, 10:25 PM   #1
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Outlet under sink, night light
I see a 110V outlet under the sink, what is that for?
Also in the rear bedroom i see about 12" off the floor on each side a small lit I assume it's a night lit, how is controled on/off?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Defendwally.org
Old 09-24-2006, 04:31 AM   #2
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I have a 110vac outlet inside my sink cabinet. The instant hot water heater plugs in to it. It's made by Insinkerator, the same as for home use - it was optional equipment on my trailer.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 09-24-2006, 04:34 AM   #3
GO Bob's Avatar
Profile:  1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
My univolt plugs in under my sink. Interested in the lights to.
GO Bob is offline   Reply With Quote
Old 09-24-2006, 02:08 PM   #4
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Lipets,
My '79 has two compartment lights in the bedroom. One is for the curbside compartment under the curbside twin, and the other is inside the center cabinet where the vacuum cleaner once lived. Actually, I stuck a little Eureka Whirlwind vac in it, and the cord is long enough to almost reach the front of the trailer.
So, does you Sovereign have compartments on both the curbside and roadside?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-24-2006, 05:16 PM   #5
Silver Mist
LI Pets's Avatar
Originally Posted by SafeHarbor
Hi, Lipets,
Does you Sovereign have compartments on both the curbside and roadside?
Lamar
It did, yes, how are they turned on?
WBCCI
Defendwally.org
Old 09-24-2006, 05:25 PM   #6
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
They have bright-metal push-buttons on one end along the narrow side of the rectangle. I think all of mine, except the rear-center, are pointing switch-forward.
Lamar
Klaatu barada nikto
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
