Old 10-24-2011, 04:00 PM   #1
Mojave's Avatar
2011 16' Sport
Tofino , British Columbia
Outlet not working
I have a 16' Bambi Sport, and the outlet in the galley right above the stove does not work. I was told to look for a reset button somewhere but can't seem to find one. We tried the fuse panel and reset everything from that end and still nothing. It was also plugged in at the time.
What am I missing?
Mojave is offline   Reply With Quote
Old 10-24-2011, 04:37 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
One ground fault interrupter (GFI) outlet may wire through and protect other outlets that are located near sinks/water. Check other outlets that are in a similar location (bathroom?) with a night light or trouble light -- is any other outlet offline? One may have the paired test and reset buttons -- these are easy to bump. Click the reset button & test again.
Find anything like that?
5 meter Langford Nahanni
Old 10-24-2011, 04:40 PM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Yours is probably a GFCI (Ground Fault Circuit Interrupter) electrical outlet.
It has a reset button between the two receptacles.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-24-2011, 04:41 PM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
That outlet is probably a Ground Fault Interrupter. Look for a breaker in the power center with a white button on it. Try reseting that breaker.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-24-2011, 04:44 PM   #5
Mojave's Avatar
2011 16' Sport
I looked everywhere I could think for that reset button (inside and out). I was told to check the bathroom first but ours is an 'all in one' so I couldn't see anywhere safe for an outlet to be as the shower could potentially spray water in the entire room.
Any hidden spots on the Bambi I may have missed?
Old 10-24-2011, 04:50 PM   #6
jdalrymple's Avatar
Jay , Oklahoma
Lots of good help here, as always. Several quick responses.
On my ’09 the GFI outlets are protected by a breaker, not another receptacle as has been mentioned.
Jeff & Cindy
'91 350 LE MH
Old 10-24-2011, 05:02 PM   #7
Mojave's Avatar
2011 16' Sport
On my 09 the GFI outlets are protected by a breaker, not another receptacle as has been mentioned.
Definitely as always a ton of help here. Much appreciated everyone!
I'm not a super tech, so should I still be looking for a reset button or is it possible this could be something else entirely? (This is a 2011 and we were the only owners).
Thanks!
Old 10-24-2011, 05:18 PM   #8
Mojave's Avatar
2011 16' Sport
Oh, so apparently Paul knows of this GFI you speak of. He found the reset yesterday but it didn't work
Old 10-24-2011, 05:19 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
On our 06 19' Bambi, the GFI outlets are controlled by a breaker in the fuse panel...a breaker switch at the top end and a white reset button at the bottom end. If that's what your set up is, try flipping the breaker switch off, then hit the reset button, then flip the breaker back on. If that sequence doesn't work try flipping it off, flipping it back on then hitting the reset button. In ours this controls the inside outlets by the sink and vanity, and the outside outlet. I discovered this when the outside outlet got a little wet while giving the Bambi a bath. Now I avoid hitting that exterior outlet cover with a direct stream of water.
TB & Greg and Abbey Schnauzer
#3954
Old 10-24-2011, 05:20 PM   #10
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
The GFCI reset is in your Power Converter Charger under the bed on the cusbside of the trailer. Push down to reset it and the up until it clicks.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 10-24-2011, 05:41 PM   #11
Mojave's Avatar
2011 16' Sport
We tried the basic reset but we'll give your suggestion a go. Thanks
Old 10-24-2011, 07:55 PM   #12
jdalrymple's Avatar
Jay , Oklahoma
To be clear the white button is not a reset, it is a test button. To reset the circuit cycle the breaker from the tripped position to off to on. Down first then up.
Regards,
Jeff & Cindy
'91 350 LE MH
Old 10-24-2011, 08:56 PM   #13
Splitrock's Avatar
Sioux Falls , South Dakota
This would be a good place for me to suggest buying a no touch voltage tester. It makes for easy tracking everything high voltage down. About $10 at big box stores. I have at least 4 of em scattered around. I've never said: "Dang! I wish I didn't have this tester."
Old 10-24-2011, 09:26 PM   #14
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Paul
It sounds like the gfci receptacles are protected by a gfci circuit breaker. All outlets within about six feet of a sink and the exterior outlet should be gfci outlets and should be protected by the gfci circuit breaker. The receptacles will look like regular receptacles. They are gfci protected because they are fed by a gfci circuit breaker. If the gfci breaker is tripped, you will not have any power at the gfci outlets. Like jdalryple said turn the breaker off and then turn it back on. If this does not work you may have a bad gfci breaker. You may also look at your owners manual. It should certainly cover this situation.
Dan
RM2500 just stopped working TouringDan Refrigerators 6 09-25-2011 11:44 PM
1971 Caravanner Outside Outlet Max Well Lights - Interior & Exterior 2 08-14-2011 07:09 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 08:19 PM
Exterior outlet on '04 Safari DJW Electrical - Systems, Generators, Batteries & Solar 6 01-23-2011 08:17 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 05:10 PM
