10-24-2011, 03:00 PM
2011 16' Sport
Tofino
, British Columbia
Outlet not working
I have a 16' Bambi Sport, and the outlet in the galley right above the stove does not work. I was told to look for a reset button somewhere but can't seem to find one. We tried the fuse panel and reset everything from that end and still nothing. It was also plugged in at the time.
What am I missing?
10-24-2011, 03:37 PM
St. Cloud
One ground fault interrupter (GFI) outlet may wire through and protect other outlets that are located near sinks/water. Check other outlets that are in a similar location (bathroom?) with a night light or trouble light -- is any other outlet offline? One may have the paired test and reset buttons -- these are easy to bump. Click the reset button & test again.
Find anything like that?
10-24-2011, 03:40 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Yours is probably a GFCI (Ground Fault Circuit Interrupter) electrical outlet.
It has a reset button between the two receptacles.
Good luck!
10-24-2011, 03:41 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
That outlet is probably a Ground Fault Interrupter. Look for a breaker in the power center with a white button on it. Try reseting that breaker.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
10-24-2011, 03:44 PM
2011 16' Sport
Tofino
, British Columbia
I looked everywhere I could think for that reset button (inside and out). I was told to check the bathroom first but ours is an 'all in one' so I couldn't see anywhere safe for an outlet to be as the shower could potentially spray water in the entire room.
Any hidden spots on the Bambi I may have missed?
10-24-2011, 03:50 PM
Jay
, Oklahoma
Lots of good help here, as always. Several quick responses.
On my ’09 the GFI outlets are protected by a breaker, not another receptacle as has been mentioned.
Jeff & Cindy
10-24-2011, 04:02 PM
2011 16' Sport
Tofino
, British Columbia
Definitely as always a ton of help here. Much appreciated everyone!
I'm not a super tech, so should I still be looking for a reset button or is it possible this could be something else entirely? (This is a 2011 and we were the only owners).
Thanks!
10-24-2011, 04:18 PM
2011 16' Sport
Tofino
, British Columbia
Oh, so apparently Paul knows of this GFI you speak of. He found the reset yesterday but it didn't work
10-24-2011, 04:19 PM
2006 19' Safari SE
Tucson
On our 06 19' Bambi, the GFI outlets are controlled by a breaker in the fuse panel...a breaker switch at the top end and a white reset button at the bottom end. If that's what your set up is, try flipping the breaker switch off, then hit the reset button, then flip the breaker back on. If that sequence doesn't work try flipping it off, flipping it back on then hitting the reset button. In ours this controls the inside outlets by the sink and vanity, and the outside outlet. I discovered this when the outside outlet got a little wet while giving the Bambi a bath. Now I avoid hitting that exterior outlet cover with a direct stream of water.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
10-24-2011, 04:20 PM
Colonial Airstream NJ
1961 16' Bambi
1997 19' "B" Van Airstream 190
Millstone Township
, New Jersey
The GFCI reset is in your Power Converter Charger under the bed on the cusbside of the trailer. Push down to reset it and the up until it clicks.
Patrick Botticelli - Colonial Airstream 595 State Hwy 33 Millstone Township, NJ 08535 - 1-800-265-9019 www.colonialairstream.com
10-24-2011, 04:41 PM
2011 16' Sport
Tofino
, British Columbia
We tried the basic reset but we'll give your suggestion a go. Thanks
10-24-2011, 06:55 PM
Jay
, Oklahoma
To be clear the white button is not a reset, it is a test button. To reset the circuit cycle the breaker from the tripped position to off to on. Down first then up.
Regards,
Jeff & Cindy
10-24-2011, 07:56 PM
Sioux Falls
, South Dakota
This would be a good place for me to suggest buying a no touch voltage tester. It makes for easy tracking everything high voltage down. About $10 at big box stores. I have at least 4 of em scattered around. I've never said: "Dang! I wish I didn't have this tester."
10-24-2011, 08:26 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Paul
It sounds like the gfci receptacles are protected by a gfci circuit breaker. All outlets within about six feet of a sink and the exterior outlet should be gfci outlets and should be protected by the gfci circuit breaker. The receptacles will look like regular receptacles. They are gfci protected because they are fed by a gfci circuit breaker. If the gfci breaker is tripped, you will not have any power at the gfci outlets. Like jdalryple said turn the breaker off and then turn it back on. If this does not work you may have a bad gfci breaker. You may also look at your owners manual. It should certainly cover this situation.
Dan
10-24-2011, 09:54 PM
2011 28' International
Chatham
, Ontario
Mojave,
Patrick speaks the truth! (I think). Had a similar issue (although not quite the same) on ours; I didn't realise that the breaker had to be pushed right down before being pulled back up into the "ON" position. You might try that on the breaker with the white test button above it.
10-25-2011, 12:54 PM
2011 16' Sport
Tofino
, British Columbia
Yes we bought a tester when we got the Bambi, and it's definitely worth having!
Thanks everyone...it finally worked Woo hoo!
Next question though...none of the outlets work when on battery, is this normal?
10-25-2011, 01:05 PM
2006 19' Safari SE
Tucson
Originally Posted by Mojave
....<snip>...
Glad you got the breaker reset...
Your regular outlets will not work when on battery power alone. They require either a generator or shore power connection.
IF you have an inverter built into your rig, there will be a few receptacles specifically set up to use inverted power. We have a factory inverter (600w) and the outlets it delivers power to are marked.
AirForums #21900
PastPrez, 4CU/WBCCI
10-25-2011, 01:21 PM
2011 16' Sport
Tofino
, British Columbia
Thanks, I'll double check but I think we tried every outlet. I didn't realize that initially, hope it doesn't become a huge issue when boondocking.
Lisa
10-25-2011, 01:50 PM
2008 27' Classic FB
Burkburnett
Your home has one source of electrical power, 110/220 volts AC. An RV has 2 sources: The 110 volts AC it gets from the power pedestal via your shore power plug. It also has an onboard 12 volt DC source provided by a battery. This is the same as what you have in your car.
The circuits are separate. The 12 volts provides power for your lights, furnace blower, water pump, radio, control power for your fridge, ignition for the water heater, etc.; basically those things that are necessary to provide a livable environment when 110 volts isn't available. The gas provides for your furnace, water heater and fridge provided there is adequate 12 volts from the battery and for your stove/oven. Some water heaters can be lit with a match. The 110 volts provides a way to recharge the battery, and allows you to run the air conditioner, microwave, TV, coffee maker, toaster, as well as your fridge and possibly your water heater without gas, etc.
If you were to "rough it" in a national park for a week, your Airstream would seem like 5 star accommodations compared to a tent and sleeping bag on a chilly rainy night, but you would have to settle for a coffee pot on the stove vs your coffee maker. Some use an inverter to convert 12 volts DC to 110 volts AC primarily to operate a 110 volt TV. Some TVs and particularly microwaves and coffee makers, etc. are high current devices and while it is possible to operate them with a properly sized inverter, the current drain on the batteries is substantial requiring a way (generator, solar array or shore power) to recharge them more frequently. Running the A/C without shore power or a big enough generator is out of the question.
Your Airstream allows you to visit and stay in places that are off the grid without having to give up all of your creature comforts, places you might have otherwise only drove past and never took the time to really enjoy. My wife actually found a curling iron that operated off little butane cartridges... She was a city girl when we first met! ;-)
AIR 47751
10-25-2011, 02:06 PM
2011 16' Sport
Tofino
, British Columbia
Thanks YankeeDoodle, this has been a learn as we go experience with a ton of help from this forum. It's definitely been a HUGE step up in comfort from tent camping. We'd like to work from the RV one day if we can, so boondocking and laptopping are gonna be our main issue. Would solar allow us to use the outlets?
