Old 02-11-2017, 06:08 PM   #1
1968 24' Tradewind
Stilwell , Kansas
Outlet Mystery
Just bought our first AS, a refurbished 68 Tradewind. Everything was working fine prior to towing it home a short distance of only 20 miles. We were tinkering around in it today and discovered none of the electrical outlets inside and the one outside stopped working. The lights throughout the trailer all work fine. Just the outlets are dead. I double-checked the breaker box and turned them off and then back on to see if something had tripped them. Still no power to the outlets. The battery is fully charged but the trailer is not plugged in to an outlet since I do not have a 30 amp service installed yet for the trailer at my home. Any troubleshooting strategies for a newbie?
Stilwellian is offline   Reply With Quote
Old 02-11-2017, 06:12 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are referring to the 110 AC outlets are you plugged into shore power?
The 12 volt batteries do not supply power to the AC outlets.
2004 Excursion 4x4
Old 02-11-2017, 06:18 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The outlets are AC. You have to be plugged in to external power for them to work. If you have any inverter there may be 1 or 2 outlets dedicated to the inverter and the inverter must be turned on.
You can plug into 15/20 amp power using an adapter but you wil not be able to run the air conditioner in most trailers.
MICHAEL
Old 02-12-2017, 05:45 AM   #4
1968 24' Tradewind
Stilwell , Kansas
I need to pick up an adapter and hopefully this will be the answer to my newbie dilemma. The learning curve has begun. Thanks for the quick reply.
Old 02-12-2017, 07:47 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You might consider getting a copy of The Newbies Guide to Airstreaming. It is very helpful, and available in hard and soft copy.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Questions on replacing exterior outlet, reflector, & mystery electric socket dgreen78 Lights - Interior & Exterior 3 08-04-2014 12:17 PM
Mystery Outlet boilermaker General Repair Forum 2 06-29-2013 03:26 PM
mystery outlet jpeterman Electrical - Systems, Generators, Batteries & Solar 8 08-08-2008 08:06 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
