Old 11-05-2011, 09:17 AM   #1
1969 27' Overlander
Albuquerque , New Mexico
Original trailer plug wiring diagram?
I'm sure the CORRECT answer is already posted, but every thread I've read seems to have a different wiring diagram, so here goes:
I'm looking for the ORIGINAL Airstream wiring/pin-out, for the the trailer plug coupler that's built into the front of the trailer. Specifically, 1969, if there were different wiring schemes.
The Overlander has a removeable trailer plug (Made by Pollack), that I need to replace. I want to make sure that the pin-out configuration on the trailer end is factory correct. I know I can just rewire the trailer plug in the trailer to match what I need, but that's not the right way to do it.
I can figure out the TV trailer side, which of course is a 7 pin.
I know there was a "standard" configuration from Airstream, but I can't seem to locate it anywhere.
Any help would be greatly appreciated!
edglenn is offline   Reply With Quote
Old 11-05-2011, 10:52 AM   #2
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
this works for me:
alclad is offline   Reply With Quote
Old 11-05-2011, 12:43 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Try this from the 70s:
center is blue /charging line
1 o'clock is right turn (red)
4 o'clock is brakes (yellow)
6 o'clock is left turn (black)
8 oclock is ground (white)
10 o'clock is back up (brown)
11 oclock is running lights (green)
Keep in mind this configuration will not match up with new RV standard wiring.
Old 11-05-2011, 05:10 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
This is how mine is wired.
I didn't care how my trailer was wired. My goal was to wire the trailer to accept a standard 7-way tow vehicle plug. I mapped the trailer with a small battery charger, a multi-meter, and a 12 volt jumper light. Then I used a 7-way tester to wire the trailer plug, and the same tester to wire the umbilical removable end.
I have three other trailers with 7-way plugs and two tow vehicles. All four trailers work with either tow vehicle and any other standard 7-way tow vehicle.
I used the diagram to build a new fuse panel and to wire the breakaway switch. The trailer wires didn't all match the service manual diagram, the umbilical wire colors didn't match the plug color codes, but . . . everything matched the 7-way tester . . . and wired to the tester, everything worked.
Old 11-05-2011, 06:35 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Splitrock's US diagram is the same as my configuration, but turned 180 degrees.
Old 11-05-2011, 07:04 PM   #6
Splitrock's Avatar
Huh?
Old 11-05-2011, 07:23 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Splitrock's US diagram above is the same configuration I described with the plug turned 180 degrees. It's the same plug from a different viewpoint.
Old 11-05-2011, 07:52 PM   #8
Splitrock's Avatar
Sorry, I don't understand. My 7-way plugs and cords have an aligning notch. My plugs and the cord accept a standard 7-way tester to configure to and to test to.
Old 11-05-2011, 08:14 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Simply put, it's the same plug.
Old 11-05-2011, 08:21 PM   #10
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Here's another view from my '72 repair manual.
I needed to replace mine as the pins were falling out. I don't remember if the direct fit replacement came from ODM or Vintage Trailer. Everything went back together without problems. I fitted new heat sealing ring terminals to the wire ends as some of the originals were corroded.
Hope this helps,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-05-2011, 10:35 PM   #11
1969 27' Overlander
Thanks to everyone for the information!
From what I can tell, the wiring diagram that Tom provided appears to very closley match what I have, looking at the backside of the plug.
The circuit breaker, and ground connections attached to the mounting bolts are exactly what I observed on my Overlander. The pin-out seems to be the same, too. I'll verify tomorrow.
Thanks again.
EDG
Old 11-06-2011, 07:51 AM   #12
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hard to say what changes have been made but this pic might help. Click to make it big...
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-29-2018, 03:30 PM   #13
1972 Argosy 22
Toronto , Ontario
12V hookup
Hello there,
I am currently planning my 7-way light/brake hookup. By '12 volt main charge line from 12 volt distribution panel', does the diagram mean the Airstream's main battery?
i.e. one line goes to the battery (+) and another goes to the battery (-)?
I'd really appreciate the help.
nico9q8743 is offline   Reply With Quote
Old 04-29-2018, 04:29 PM   #14
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
My 68 was not wired like the diagrams showed it should have been. It came with the old 6 pin connector not the newer 7 blade style. I had to apply 12v to each pin and see what it did. Who knows when or who messed with it before I got it. Once I found what each wire did, I wired the plug to match the new "standard" 7 pin plug. Bottom line, don't assume it is wired like the diagrams show it should be.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Need a 35 Amp Bargman 110v Plug!! 1958 745classic Batteries, Univolts, Converters & Inverters 12 09-17-2017 01:38 PM
Airstream Travel Trailer 1975 Vintage Original 29' eBay Watch Airstreams on eBay 0 04-29-2011 12:00 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
Original External Water Tank fill cap for 69 commander31 Fresh Water Systems 1 02-07-2011 01:38 PM
uh, oops. original Tradewind dinette design? SpaceEgg 1959-69 Tradewind 4 01-21-2011 08:54 AM
