Old 05-12-2010, 07:19 AM   #1
98 33' Beach House
1998 33' Land Yacht
Beaufort , South Carolina
Onan running but no power to a/c....
I have a 98 LandYacht w/Onan Marquis 5000. I use the generator during trips up I-95 from SC to MD in the warmer months to run the roof a/c, cofee maker, microwave. The gen has 315 hrs. total and has performed flawlessly during the past 5 years.
So changed the oil today and fired it up but NO power to the appliances at all.
Is this is diode issue in the generator or have I tripped a fuse somewhere?
BTW, all appliances work well when plugged to shore power.
Chip in Beaufort, SC
mossyoaks is offline   Reply With Quote
Old 05-12-2010, 08:20 AM   #2
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Check the ckt-bkr on the generator
jkcru is offline   Reply With Quote
Old 05-12-2010, 08:45 AM   #3
345bill's Avatar
Las Vegas , Nevada
On our 345 MH the Onan has two ckt-breakers and one in-line glass fuse right at the gen. and they would be the first things to check, especially since yours is ok on shore power. Yours should be similar.
345bill is offline   Reply With Quote
Old 05-12-2010, 09:05 AM   #4
98 33' Beach House
1998 33' Land Yacht
yep. but no.
Found those already. Still no power.?
Also, pulled out my Onan Manuel and now have a much better idea of how things are 'supposed to' work (along with wiring diagram).
My LY has two model TS-30 power switchs that control the transfer from gen to house pwr. I'll be testing those today.
I've heard that the problem can be the diodes in the gen itself. Lots of big boats here in Beaufort w/these Onans and some have needed their diodes renewed.
I'm hoping not.
Old 09-06-2010, 08:29 PM   #5
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
Did you figure out what went wrong? My gen just started diong the same thing. Runs but no power out.
BarnacleBill is offline   Reply With Quote
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Cummins Onan, Has anyone used them? DFord79 Generators & Solar Power 18 11-09-2007 09:50 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
