Old 04-14-2010, 07:08 PM   #1
potlatch , Idaho
Onan Generator No Start
I just bought this motorhome. The generator won't start. It has no spark. It's an Onan 4kw. Emerald I. There is power at the positive side of the ignition coil and on the negative side. I don't think the LED on my test light is flashing when I ground it and test the negative side to see if the points are working. I used an ohmmeter and measured across the pos/neg of the coil and there's continuity. How do I test the secondary side? Any suggestions?
hilly is offline   Reply With Quote
Old 04-14-2010, 07:22 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
"This motorhome" does not get it. What year, diesel or gas? Did you replace the points, plug and filter?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-14-2010, 08:01 PM   #3
potlatch , Idaho
It's a 1986 Fleetwood Southwind. Gasoline. Haven't replaced anything, but I suspect the ignition coil.
Old 04-14-2010, 08:45 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
pull a spark plug, hook up the lead, lay the plug on the engine and watch for spark while cranking. It should be fat and blue....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-14-2010, 08:58 PM   #5
Ottawa , ON
Well, it's an '86, and the gennie is something I'd want to be able to count on (if I was so lucky as to have one).
Why not treat it to new wires, plugs, coil, and points and change its oil: live it up!
You could even go overboard and clean it up! hehehehe...
Old 04-14-2010, 09:57 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Onan that old and probabley hasnt been started for a while.I would suspect first a Condenser. Change the points and condenser. Then make sure there is power coming to the + side of the coil. Coils go bad also. Get a really good spark tester. If it hasnt been run for a while you could also be lookin at a Carb overhaul.They get all gummed up when they set with old fuel.
Good Luck LET us know what you find
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-14-2010, 10:02 PM   #7
Ottawa , ON
Good point, Mike. I was just concentrating on what he said about no spark.
A gummy carb is almost for sure if it wasnt't used, and the old gas just dried up in there, shellacing the innards of the carb...
So that's it, hilly, ya gotta do a carb rebuild to, and the gennie will run like a new one!
Old 04-14-2010, 10:28 PM   #8
potlatch , Idaho
I checked for spark at the plugs with my spark tester, no spark. Tested for power at the coil +, there is power. I disconnected the points lead, cranked the engine and grounded the lead momentarily. Still no spark. I used an ohmmeter to check for continuity from the coil + to coil -, there is continuity. I don't remember how to test the secondary part of the coil.
There is fuel to the electric fuel pump and fuel at the carb. I sprayed carb cleaner into the air intake but still no start.
Old 04-15-2010, 01:31 AM   #9
Maniacal Engineer
barts's Avatar
If you can get current to flow in the primary, interrupt it and there's no spark from the secondart you have one or more of:
1) a bum coil.
2) a bad spark plug wire
3) a shorted/fouled spark plug
Odds are quite good that it's the coil.
- Bart
Bart Smaalders
Menlo Park, CA
Old 04-15-2010, 08:18 AM   #10
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
The points on these engines get corroded rather quickly. Try just filing the points and see if that solves your problem.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 04-15-2010, 09:05 AM   #11
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
ignition
once you figger out the points have corroded, or whatever, before you spend $ on points-check out Pertronix-they make electronic ignition systems for just about everything. points/condenser have gotten horribly expensive-one time $ on electronic ignition.
and after all that probably still wont start cuz the fuel is bad-back flush the fuel line or pump it through til you get a good flow of FRESH gasoline (don't ask me how to be sure it is fresh) the gas we get today is lucky to explode when compressed, let alone when it has sat for awhile (just a mild stretch of the truth, there).
wmarsha is offline   Reply With Quote
Old 04-15-2010, 09:44 AM   #12
Mike Leary's Avatar
Images: 11
Most mechanics suggest you just stay with the tried and true points; could be Pertronix is a good product, but my guy tells me the Onan e-ignition was junk.
Old 04-15-2010, 12:17 PM   #13
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Exclamation Generator No Start
I agree with Mike Leary. Use the onan points and condenser. To make the gen run you need three things: Ignition, Compression, Caburetion. Take any one out of the equation and it will not work. If the carb is gummed up, you might as well get a kit for it and overhaul it and clean it.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 04-15-2010, 01:23 PM   #14
Ottawa , ON
Suck, squish, bang, blow: that's all the "infernal combustion" motors do.
Spend a few bucks on a few new electrical bits (so the "bang" part can work), clean the carbs (so that it can "suck"), and then go on to all the other more glamourous parts that will need your attetnion, hilly.
Onan Generator af12680252 Land Yacht/Legacy Motorhomes 10 09-28-2011 07:39 AM
Propane powered Onan won't start Paul Dobbin Land Yacht/Legacy Motorhomes 29 10-03-2010 04:29 PM
Onan Generator gunworks Land Yacht/Legacy Motorhomes 7 07-22-2009 08:46 PM
Onan Generator Hillgenberg Generators & Solar Power 2 08-24-2006 12:32 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
