Old 08-27-2015, 01:19 PM   #1
ITowSilver's Avatar
OK to swap single outlet for double?
Outlet for front TV plug has one side blocked by factory. Would like to also plug Sat converter in that outlet. Any reason not to swap double outlet for existing single?
Thanks.
Sam
AS: 2015 27" Flying Cloud
TV: 2013 Lincoln Navigator
WBCCI# 2720
ITowSilver is offline   Reply With Quote
Old 08-27-2015, 01:37 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I think they put in whatever outlet they grab. It seemed to me that the inverter outlets were intended to be singles and the shore power ones double. But I had a single by my rear television. When I was at the factory for some warranty work they changed it to a double.
2019 Ford Expedition Platinum
Wayne&Sam is online now   Reply With Quote
Old 08-27-2015, 01:49 PM   #3
2007 22' International CCD
It's possible to carefully open the second outlet on the blocked ones with a hobby knife. There are other threads on this forum about that. Try searching.
rmkrum is online now   Reply With Quote
Old 08-27-2015, 03:26 PM   #4
ITowSilver's Avatar
RMKRUM: I tried unsuccessfully to search before posting. Didn't get the reference in your post, will you please resend it.
Sent from my Atari 400 using Airstream Forums
WBCCI# 2720
Old 08-27-2015, 03:41 PM   #5
ITowSilver's Avatar
I was able to research and found the thread. Now what to do now.
Thanks again -- Sam
WBCCI# 2720
Old 08-28-2015, 12:32 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
In our rig only the inverter plugs are singles.
We use those plugs expanders that you plug into the outlet to give you three additional places to plug things into. Have had no issues doing this.
TB & Greg and Abbey Schnauzer
#3954
Old 08-28-2015, 06:59 PM   #7
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Of course you can use a theefer -- three for one, also known as a cube tap (or, in film lighting work where it is ironically known as a 30A junction box.)
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 08-28-2015, 09:51 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The metal guts are in place for the connection. One just needs to open the slots and hole for the typical US 15 amp plug. The other alternative is to install a real outlet versus the super cheap RV outlet Airstream installs.
I replaced all the Airstream outlets with the Hubbell 20 amp rated GFI shallow duplex outlets.
Double pane to single pane window conversion ronstory Windows & Screens 8 10-07-2017 06:38 AM
Single Outlet Not Working gmp61 Electrical - Systems, Generators, Batteries & Solar 2 05-11-2012 08:08 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Single or double axles? dan_lemire Buyer Guidelines 11 02-13-2006 11:37 AM
Axle upgrade, single to double William8979 Axles 17 02-13-2005 08:23 AM
