Old 10-26-2006, 08:57 PM   #1
yhk
1973 29' Ambassador
Oneonta , Alabama
OK I'm confused
I have a 73 ambassador, and do not know how to hook to the antenna. I have a white box with a 12 volt plug in and two small holes for antenna. How do I use the antenna?
yhk is offline   Reply With Quote
Old 10-26-2006, 09:44 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
My '66 TW has holes next to the front window for an antenna. As we were about to leave the PO with the trailer he said wait then came back with the antenna. The wire for it went down inside the wall, under the floor and up to an antenna plug on the shelf on top of the fridge. Not really much room for a TV but it looks like a factory installation. Maybe your antenna wires also go down the wall to wherever too? I have not installed my antenna but cut patches from aluminum tape to cover to outside holes. You can hardly see the patch.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-26-2006, 11:55 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
antenna connector
Seems to me that we had a discussion on these connections before. There are pictures of this little connector. Try this link and see if this is what you are talking about.
http://www.airforums.com/forum...acle-8815.html
Hope this helps
Larry and Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 10-27-2006, 08:01 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Stop at Radio Shack they still carry the plugs. For less than ten mins and $5 problem will be solved.
Old 10-27-2006, 08:56 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
when I was looking for one, Radio Shack didn't have them...never heard of them...nothing in their catalog...bupkiss.
Another option is to replace the whole thing with a modern 12v socket/coax tv antenna amplifier/connector.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-27-2006, 09:03 AM   #6
loudruff's Avatar
1989 29' Excella
Ditto
Radio Shack didn't have these here either. We went to an old (established) TV repair shop that had been around for awhile and asked....Sure enough. they knew exactly what they were and had several in an old parts bin that was laying around the shop!
Larry and Lou
Air #2695
TAC- OH 2
Old 10-27-2006, 09:11 AM   #7
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
If you will look at posts 11 and 12 in the referenced thread above, you'll see an entry in post 11 from retro-active-couple offering to purchase the needed leads and ship them to anyone interested in having one. They have a source locally. I contacted her, ordered and received two of the leads so that I'd have a spare. At the time (04-29-04), they were $3.39 each. She kindly shipped them. Cost was minimal. They weigh very little. Contact retro-active-couple through the forum's private message system by clicking on her name in post 11 of the above thread. She'll likely be more than willing to purchase one and ship it to you. Then you'll have the original equipment. GStephens
GStephens is offline   Reply With Quote
Old 10-27-2006, 09:25 AM   #8
1976 25' Caravanner
Campton , New Hampshire
You may also find one at an older RV dealer . It's called a "Braund 300 ohm TV jack ( small )" pn 11617 (wood grain) or pn 11616 ( ivory ). Don't know if it can be ordered or not.
ticki2 is offline   Reply With Quote
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 10:35 AM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 10:36 PM
Help - I'm Confused timcumming Clearcoat, Exterior Paint & Trim 16 02-26-2003 02:23 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 06:15 PM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 09:26 PM
