Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-20-2006, 11:03 PM   #1
Profile:  1976 26' Argosy 26
St. Albert , Alberta
Oh where oh where does the 7pin go?
Hi all,
My 7pin connector cable snakes into the A-frame, then probably pops up near the converter and battery at the back, but can you tell me how it gets back there under the floor? Is it threaded through the crossbraces?
I'd like to reuse the cable instead a rethreading a new one...
Cheers!
Name:	Day Seven 7 Pin Disappears (reduced).jpg
Chopper is offline   Reply With Quote
Old 09-20-2006, 11:08 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
On my 24' Argosy it comes through the floor just aft of the freshwater tank. If you have a gaucho armrest at roadside front (is your water pump under there too?), look under there and try looking for connectors about on the aluminum panel about a foot or 18" below the back of the pano window.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 09-20-2006, 11:35 PM   #3
I'll have a look
I'll look again later, but from what I recall, there's nothing up front. Does it come through as a thick cable or individual colored wires?
Thanks!
Name:	Water pump in situ (day two, reduced).jpg
Old 09-20-2006, 11:54 PM   #4
Pic below is how my 24 is wired. I almost recall other Argosy threads and models that had the 7-pin wire go all the way back to the Univolt area. I don't recall.
I do know that the umbilical comes out the back end of the roadside A-frame rectangular tubing -- underneath your belly skin/banana wrap at about the roadside first rib -- follow rivet line down from the back edge of the pano window.
Name:	Roadside below gaucho.jpg
BobStream
Old 09-21-2006, 05:29 AM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Thanks!
It SHOULD be behind the wood paneling on the wall in your photo.
(No Longer at Inland RV)
Old 09-21-2006, 07:48 AM   #6
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
nothing there...
The 26ft'r is a bit different (I believe). I've had my front interior all apart (not taking off the skins though) and I don't have that box. I believe it's all under the belly wrap on the street side. BUT - I've not actually looked there.
Happy hunting!
Marc
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
