Old 03-18-2016, 01:36 PM   #29
2015 30' Classic
Pleasanton , California
(propane + cafetiere) OR (propane + aeropress) = great coffee = 0 A
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-18-2016, 01:53 PM   #30
Lily&Me's Avatar
Normal , Illinois
We went to all-stove-top-percolator, all the time, 3-4 years ago, after carrying it primarily for boondocking.
The percolator makes better coffee, and then no need for duplication in the limited space of the Interstate.
Those tiny book lights that you can attach to a book, magazine, Nook, etc., give off a tremendous amount of focused light, the battery lasts a long time....then no need for those reading lights.
Maggie
Lily&Me is online now   Reply With Quote
Old 03-18-2016, 04:08 PM   #31
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
We like to roast our coffee ourselves, use a hand grinder and then french press. After that I use a hand foamer for my MCT Oil and Butter I put in the coffee, top it off with Cinamon. Oh man. Yum. No power required.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-18-2016, 04:15 PM   #32
Lily&Me's Avatar
Normal , Illinois
That's more labor intensive coffee than I am interested in, tho am always willing to drink fancy coffee that others make.
Maggie
Old 03-18-2016, 06:27 PM   #33
kenen42's Avatar
2011 27' FB Flying Cloud
Delmar , New York
On some fridges there is an electric heating element to prevent condensation from forming on the strip between the freezer and refrigerator. Some models (like mine) don't have a switch to control it, it's always on. I forget the numbers on how much it draws but I think it was between a 1/2 and 1 amp, 24/7 which adds up quickly. Fortunately the wire for it was clearly identified in the wiring diagram pasted inside the exterior refrigerator compartment. There is now a switch in there to turn it off.
kenen42 is offline   Reply With Quote
Old 03-23-2016, 03:26 PM   #34
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
Originally Posted by idroba View Post
The water pump takes no power when not pumping water, so there is no need to turn it off when you are out, or inside not using any water.
When the pump runs, it takes 4 to 7 amps. It pumps about 3 gal/minute when operating. So, in 10 minutes it can pump a 30 gal fresh water tank dry.
10 minutes is 1/6 of an hour. So, if the pump takes 6 amps per hour, 1/6 th of that is 1 amp hour to pump 30 gal of water. If it pumps the same 30 gal over two days, the same 1 amp hour is used over two days.
The water pump is NOT a big user of the stored battery energy. And it does not take any power when it is not running, so turning it off and on when you want to get a cup of water, or flush the toilet, does not use less battery capacity.
Thanks for the tip. I think it was actually our AS salesman for Bambi #1 who recommended turning off the pump when it was not in use!
However.... when we need to save battery power, like on our recent 7-day off-grid camping trip in the Mojave desert, we generally have several conservation issues going on at once, such as fresh water and space in the waste water holding tanks. We found that one toilet flush with the water pump turned on would put enough water in the system that we could turn off the pump and flush 2-3 more times without battery power for most (cough, ahem) "uses." Ditto for the bit of water still able to flow from the sink taps.
Somehow for us it makes sense, but possibly more for the fresh and waste water than for the battery.
Incidentally, with two six-volt batteries fully charged prior to our week off-grid, we used our generator just once, for about two hours. That charged the batteries enough for the rest of the camping stay, with careful useage.
I also have a little pocket-size solar panel device called a Power Monkey that we bought from REI that is capable of recharging a Kindle or cell phone. But no cell-phone service in most places where we would be off-grid around Death Valley and the Mojave National Preserve.
Len n Jeanne is offline   Reply With Quote
Old 03-23-2016, 04:28 PM   #35
Len and Jeanne
A former post of mine on Television power use:
http://www.airforums.com/forums/f450...er-138719.html
And a repeat of my measured power in my 2014 FC 20'
Amp draw for things in a 2014 20' Flying Cloud "Bambi"
Measured with a Tri-Metric meter and 100 amp shunt.
Water heater, when flame on: .74 amp
Refrigerator, flame on: .32
Refrigerator fan only: .55
Bed lights, reading, each: .17
Bed lights, overhead, 3: dimmest .1
brightest .52
Main overhead lights, 6 dimmest .23
brightest 1.18
Step light: .06
Scare light (floodlight) .13
Table light: High .62
Low .31
Kitchen lights (either, there are 2) High .38
low .19
Bath lights (2, each with high and low) All .72
one high .38
one low .19
Every LED light inside on at the same time: 3.9 amps
Fantastic fan, each: High 1.55
Medium 1.22
Low .93
Bath fan (little, 4" round) 1.5
Kitchen range fan: 2.4
Kitchen range fan lights (halogen) 3.5
Furnace, 18,000 btuh, direct vent burner on: 3.65
fan only: 2.9
Radio, all off, no lights showing: no measure
Radio, disco lights on, no volume: .7
Radio, lights on, medium volume: .9 to 1
Propane detector: .06
(note: mis measured and posted an error recently on the forum, I was off by a factor of 10)
Pump: (variable speed) 2-4
1000 watt sine wave inverter, on, no load 1.76
with TV and DVD plugged in, but not on: 1.76
TV on and DVD playing: 3.6
TV on DVD playing, + radio on for sound: 4.9-5.3
Very small microwave, supplied by inverter: 89
Toaster, supplied by inverter: 75
Apple Mac Book Pro, charged running from
inverter: 3.1 to 3.3
Propane detector Measured 9/1/15 0.076
Inverters (2) Measured 9/1/15 0.02
This is really helpful, idroba. Especially now that I realize how much battery power cooking a meal uses, we might go more towards those supermarket prepared foods we've always resisted, for longer trips where we can't take everything prepared from home. (Our home-made stuff tastes better, is healthier, &c.) We don't carry a toaster. Muffins are fine.
The onboard inverter use seems unnecessary. I bought a portable inverter at an auto parts shop and it plugs into the truck cigarette lighter. It works fine for recharging the laptop, which is where I watch DVDs. If we wanted to watch TV we'd stay at an RV park with hookups.
We really keep the thermostat low when we need to use the furnace at night. Last night we set it for 55F, but that was a bit much. We're headed to the Grand Canyon, though, where we need to run it at night due to sub-freezing temps.
We're coffee hounds, as well, but make it the old-fashioned drip way. We found a collapsible cone at REI to hold filter papers. Boil water on the stove, pour into the cone, then the coffee drips into a stainless steel insulated carafe or directly into the thermos.
We carry a Honda 2000, which is good for running anything but the AC.
Old 04-26-2016, 05:11 PM   #36
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
NWGetaways,
Thanks for this thread 😃👍🏻 Would you please list your electric system components? Type and number of batteries, 30 or 50 amp, converter, etc.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 04-27-2016, 07:45 AM   #37
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
Hi Caroyl,
I have two 6 volt Lifelines, 220 amp hours each. The only inverter I have is a small 175 watt unit that plugs into the 12 volt socket. Adequate for TV, DVd, and recharging iDevices.
NWGetaways is offline   Reply With Quote
Old 04-28-2016, 10:09 AM   #38
Caroyl's Avatar
1964 26' Overlander
Off Grid Electricity - A Minimalist Approach
Originally Posted by NWGetaways View Post
Hi Caroyl,
Thanks! What converter do you use or do you just recharge with something else?
Caroyl & Tim
WBCCI # 31088
Old 04-28-2016, 11:15 AM   #39
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
I have a Progressive Dynamics 9260 in the 19' and the stock 3 stage WFCO n the 22'.
Minimalist vent fan upgrade for 68 Overlander fitzjo1 Roof Vents, Skylights & Fans 0 07-05-2015 01:33 PM
Minimalist restoration of Caravel hodol88 Interior Restoration Forum 6 09-02-2014 08:02 AM
Winter Living off grid in Vermont with woodstove cmell Winter Living 59 10-28-2009 04:02 PM
Seeking To Go Off The Grid! privacy2 Member Introductions 4 07-11-2006 06:31 PM
