Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-14-2006, 08:06 PM   #1
Chopper
Profile:  1976 26' Argosy 26
St. Albert , Alberta
OEM Converter in my Argy26?
Hi all,
The following pictures are from my '74Argy26 deconstruction project. Is this a factory arrangement? I haven't moved anything, it was like that behind the bathroom closet. I am going to rewire everything but the electrical system is something I'm totally unfamiliar with and will have to study up on.
Thanks!
Name:	Day Five Measuring Converter (reduced).jpg
ID:	25927  Click image for larger version
Name:	Day Five Measuring Converter CloseUp (reduced).jpg
Chopper is offline   Reply With Quote
Old 09-14-2006, 08:10 PM   #2
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Originally Posted by Chopper
Hi all,
Thanks!
Yep that's the original it is called a Univolt. I throw them as far as I can, the technology is old and they have a tendency to boil bateries dry.
Second thought there are some people who might buy it. You never know try Ebay.
Peace
Gary
Janet's Husband is online now   Reply With Quote
Old 09-14-2006, 08:26 PM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Gary -- Second thought is to take it down to the bait shop and sell it as an anchor. Chopper, search the forums on 'bestconverter' -- we have a commercial vendor who sells Intellipower with the Charge Wizard that is much more modern and better controlled. Search on those latter terms also.
CanoeStream is online now   Reply With Quote
Old 09-14-2006, 08:46 PM   #4
Chopper
Got it, thanks!
Thanks for the leads. I'll make sure to investigate the upgrades. In the meantime, anyone here want this and the fuse box?
Cheers!
Old 09-14-2006, 08:55 PM   #5
CanoeStream
Images: 13
Don't unload the fuse box! I haven't done this but understand you need to re-use that item. Ask more questions -- we'll see if anyone more knowledgeable can fill you in. Certainly ask Randy -- he's the commercial vendor mentioned above.
Old 09-14-2006, 09:03 PM   #6
Chopper
Oops, you're right.
Thanks, I'm getting ahead of myself here. I am so much into wanting to get building that I'm hurrying the "taking apart". I need the fuse box? I was going to upgrade that item too, but I'll see about some more thread-searching and answers.
In the meantime, I'm learning about 7-pin wiring and thinking about what to do about all those wires my buddy snipped during the deconstruction of the interior! That's why I'm thinking I should redo the wiring completely afresh instead of chasing down the cut ends.
Cheers!
Old 09-14-2006, 10:24 PM   #7
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
You can get a new WFCO converter with a new fuse box that uses the newer spade type automotive fuses if you don't want to keep the original.......just need to connect a few more wires.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 07:52 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 09:45 AM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 09:30 AM
Converter box floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 11:34 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 10:49 PM
test
