Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-04-2015, 07:43 PM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
OEM ceiling extractor vent fan on '72 Sovereign ?
Hi All,
is this fan oem? can't see mentioned anywhere in the owners manual ! nor can I find a switch. i didn't even know it worked until up on the roof replacing the vent lid and clearing some debris and it suddenly sprung into life, i couldn't work out how to switch off, so pulled the wiring lose which promptly blew a fuse to the switch board... at the fan stopped running , it was shot, noisy and rattling.
thinking of replacing entire unit with a fantastic fan at some point, so at least there is 12v power up there.
nickclifford is offline   Reply With Quote
Old 10-04-2015, 07:57 PM   #2
1981 31' Excella II
New Market , Alabama
Yes it looks original. I am not so sure I would go with a fantastic fan since they require removing the OEM vent housing. This vent housing supports the roof. If you do put in a new vent make sure you add some structure between the inner and outer skins.
Perry
Old 10-04-2015, 08:46 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I replaced the o.e. vents with remote controlled Maxxair vents.
Your '72 is like my '69 no need to worry about the roof its supported on both sides by the inner structures that run parallel the length of the trailer.
I found the best price on Amazon . The Maxxair has 9 speeds and the cover is the rain shield also.
ID:	249694   Click image for larger version
ID:	249696   Click image for larger version
Name:	AS 1st trip.jpg
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 11-14-2015, 10:03 PM   #4
1972 31' Sovereign
felton , California
Perry
i went ahead and pulled out the old fan today, the roof around is kinda weak, but is that a concern ? the new fan will add some support again i guess ..
if this is an issue, guess I could slip so wood cut to size to add structure and support, but not sure why this could be an issue ? thanks
Old 11-15-2015, 06:33 AM   #5
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
fan
FYUI, the motor, fan blade, and shroud are all available new from Airstream (inland) I rebuilt mine works great! I'm thinking of adding the fans to my 2 other vents, If I can find the 12v up there. John
moparjohn is offline   Reply With Quote
Old 11-16-2015, 08:41 AM   #6
1972 31' Sovereign
felton , California
thanks! i'll remember that for my next AS ! when you (inland) are you referring to Inland RV?
Old 11-16-2015, 10:35 AM   #7
moparjohn's Avatar
1973 25' Tradewind
fan
yes
sovereign
Maxxair Vent cover install on OEM vent perryg114 Roof 1 08-29-2015 09:19 AM
1968 Sovereign Ceiling Vent Fan Motor & Riser krrcolorado Roof Vents, Skylights & Fans 1 06-12-2013 10:37 AM
Ceiling vent fan woodja Classic Motorhomes 4 07-29-2011 08:20 PM
Interior Ceiling Vent Fan Ag'71 Lights - Interior & Exterior 0 09-23-2009 08:43 AM
ceiling vent fan question? wayne.yl Roof Vents, Skylights & Fans 6 06-24-2004 03:49 AM
