Old 04-02-2003, 06:45 PM   #1
Jabba's Avatar
1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
Oddball size battery, help!
I pulled the battery out of the box on the front of our '55 tonight. It is indeed a tractor battery with dimensions of 19 1/4 L x 4 1/2 W x 9 1/2 H. Group 3ET. Does anyone know if they make that size battery in a deep cycle? If so, any leads as to where to find one? Sears is trying to sell me a pair of gel cell wheelchair batteries at $70 each. Help!!!
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 04-02-2003, 07:02 PM   #2
The following site has info & links to everything and more about batteries (including links to manufacterers):
CAR & DEEP CYCLE BATTERIES
femuse is offline   Reply With Quote
Old 04-02-2003, 09:03 PM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Lots of manufacturers still make that size battery... but not in deep cycle.
http://www.interstatebatteries.com/B...ct_3ET-VHD.htm
Maurice
Old 04-03-2003, 02:23 AM   #4
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
That's the size our 59 would have used also. Somewhere along the way a new battery box was fabricated to fit a more conventional/current sized battery. I had at one point throught the narrow box was for a pair of 6v batteries that would have still been very common durring the time.
Since our original box is missing and the current box interferes with how large of propane tanks I can run as well as being in bad shape, I'll be relocating the battery. My plan is to make a tray between the frame rails like current A/S models are running I may atempt to fabricate a aluminum cover.
I intend to take photos but that modification is a ways off at this point. I'll post up when it's done.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
battery size? larry smith Electrical - Systems, Generators, Batteries & Solar 2 08-12-2002 08:29 AM
