Old 12-26-2015, 04:24 PM   #1
1954 18' Globetrotter
Atlanta , Georgia
Odd electrical issue
We have a 1954 Airstream. Somewhat at random the electric throws the breaker when plugged in. At home it has been plugged in for 3months with no issues and then all of a sudden it throws the breaker. Any thoughts suggestions and/or recommendations for repair places in the great Atlanta GA area.Thanks
SFPosner is offline   Reply With Quote
Old 12-26-2015, 06:49 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I suggest replacing the breaker that is tripping. You can do this in just a few minutes.
Unplug from shore power. Remove the breaker box cover. Pull out the breaker (it will pull out with fingers and slight pressure straight out). Loosen the one screw that holds the wire. Take the old breaker with you to Lowes or HD. Get the exact same breaker (do not let a sales person tell you a different type will work).
edit: If it happens to be a GFCI breaker there will be two wires. Pay attention to the color and location of the wires before taking them loose. Put them back exactly as they were.
Alan
Old 12-26-2015, 06:57 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
There is a device that measures the isolation of the wiring. The common name is for this device is Megger, but that is just the name of a manufacture. If simple replacement doesn't work for you then call the around and find a shop that has one. Just make sure your appliances are switched off, if possible unplug them.
sgschwend is offline   Reply With Quote
Old 12-26-2015, 07:14 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
another thought: Does your trailer still have the original single stage Univolt converter?
With shore power on, turn that tripping breaker off, then check to see if the receptacle that powers the converter is on that circuit (by pluging in a light or tool or using a meter). If there is no power, it is on the tripping circuit. It could be that the converter is drawing more current, occasionally, than it should.
Alan
Old 12-27-2015, 10:14 AM   #5
Atlanta , Georgia
Thanks. It was re-wired by the previous owner when restored. Will try the suggestion.
Old 12-27-2015, 10:52 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
First and simplest thing to check, is the shore power plug tight in its socket? A loose connection can cause random breaker tripping, as the loose fit causes increased electrical resistance. And as the resistance increases, so does heat. A plug that fits loose in its socket will get warm to the touch.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-27-2015, 11:26 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Wouldn't a loose shore power plug cause the breaker at the shore power electrical panel to trip, instead of one of the breakers inside the trailer's panel?
Alan
Old 12-27-2015, 01:33 PM   #8
The OP didn't say WHICH breaker was tripping; all he said was "the breaker."
WBCCI #1105
TAC LA-4
Old 12-28-2015, 04:33 AM   #9
Atlanta , Georgia
I've isolated it to one of the two breakers in the trailer. I expect it is a short somewhere in the trailer. Now all I have to do is find it.
Old 12-28-2015, 05:20 AM   #10
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Odd electrical
One thing that will trip GFIC breakers is a generator which is not properly grounded. If there is some interruption in the shore line, this may mimic a ground fault in the eyes of the breaker and create the issue. Even in new wiring these GFIC breakers can be very fussy.
Just my thoughts...
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-28-2015, 05:29 AM   #11
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
A 1954 trailer is unlikely to have a GIFI. Finding a partial short in a trailer is a pain. It is likely an old trailer has degraded insulation on one wire and a rub through to contact aluminum. Sometime,s it means checking at each outlet and lifting wires to isolate the problem.
Old 12-28-2015, 09:19 AM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by dwightdi View Post
A 1954 trailer is unlikely to have a GIFI<<snip.
I think originally there would have been fuses, not breakers. Definitely there was no GFCI in 1954. The trailer was re-wired at some point.
Alan
Old 12-28-2015, 02:47 PM   #13
Atlanta , Georgia
The trailer was re-wired several years ago (not by me). The likely cause is a short somewhere in the trailer. I can separate it out to the line that runs the interior lights/outlets. Don't know how to isolate it beyond that.
Odd Regulator Issue kamadeca LP Gas, Piping, Tanks & Regulators 4 06-16-2014 11:27 AM
Odd electrical ground / neutral issue on '89 370 classic romakdaddy Classic Motorhomes 29 10-23-2013 05:44 PM
1973 Safari odd rear exterior lights issue DonnyK Lights - Interior & Exterior 9 10-22-2013 10:02 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
